Cooler Master V650 SFX Gold 650W Power Supply Review
Transient Testing
For those of you that are curious as to some of the reasoning and equipment behind our PSU testing program here at TheFPSReview, we have put together an introduction for you that shares a lot of the behind-the-scenes of the program. This program is based on what the author developed at [H]ardOCP and utilizes the equipment bequeathed to the author by Kyle Bennett. The testing we are conducting today is exactly as described in that document and will continue with our Transient Testing.
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the Cooler Master V650 SFX GOLD at 45c. This makes Test #1 equal to 172W by loading the 12v rail to 12a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~320mV drop on the 12v rail and ~40mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~30mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the Cooler Master V650 SFX GOLD at 45c. This makes Test #2 equal to 323W by loading the 12v rail to 24a, the 5v rail to 3a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~250mV drop on the 12v rail and ~40mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~25mV drop.
The Transient Load Tests results for the Cooler Master V650 SFX GOLD are passing and remarkably good for what this unit is today. In today’s testing, the V650 SFX GOLD saw the loaded 12v rail post a peak change of ~320mV and the loaded 5v rail post a peak change of ~40mV. The unloaded 5v peak change during the 12v load was ~30mV. Those numbers are, in an absolute sense, passing. In a relative sense, this unit is, again, harder to place as we have not seen any other 650W SFX power supplies to date here at TheFPSReview.
However, among the other two 650W ATX units we have seen, this unit bests the Seasonic FOCUS GM-650 and the GIGABYTE P650B. As with the regular load tests, this is rather impressive given the much smaller footprint that this unit is working with yet still giving these kinds of results. Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
Paul Johnson
