Yuel Beast Motif Monument ITX Case Review
Yuel Beast Motif Monument Temp and Noise Tests
Testing Scenarios
  • All stock – CPU defaults on the MSI Z490, four Cooler Master case fans
  • Testing Scenarios
Our tried-and-true loading method is to use a combined load of Cinebench R23 multi-core and the default Furmark GPU stress test. With the CPU overclocked to 4.7GHz and the GPU power limit raised to 108, the 2022 Mini Case Review Rig is able to pull a steady 400w at the wall and produces 46dB of noise if all fans are run at their maximum.
Yuel Beast Motif Monument ITX Case Review Benchmarks
How we interpret the results
Things to keep in mind:
  • Lower power usage directly correlates to lower system performance
  • Lower temperatures at the same power usage result from superior cooling
For the Yuel Beast Motif Monument, we found after significant tuning that our i5 10600K can run at 4.7GHz stable when set to 1.255 VCore in the BIOS along with LLC 7, resulting in a load VCore of 1.265V as measured in CPU-Z.
John Tharp
