Corsair has announced the H100i RGB ELITE, H115i RGB ELITE, and H150i RGB ELITE Liquid CPU Coolers, its latest line of all-in-one RGB CPU coolers for newer Intel and AMD sockets. Each new AIO cooler comes in either 240 mm, 280 mm, or 360 mm sizes and features Corsair’s new AF ELITE Series fans, which are also available for purchase separately in 120 mm and 140 mm sizes. Corsair’s H100i RGB ELITE, H115i RGB ELITE, and H150i RGB ELITE Liquid CPU Coolers are available today from the manufacturer’s webstore and authorized retailers and distributors.
CORSAIR ELITE Cooler Lineup
RGB ELITE Series | ELITE CAPELLIX Series | ELITE LCD Series | |
Sizes | H100i, H115i, H150i | H100i, H115i, H150i, H170i | H100i, H150i, H170i |
Fans | AF ELITE | ML RGB | ML RGB ELITE |
Fan Bearing | Fluid Dynamic | Magnetic Levitation | Magnetic Levitation |
Fan Noise | 10 – 30 dBa | 10 – 36 dBa | 10 – 30 dBa |
Fan RGB | X | 8 RGB LEDs per fan | 8 RGB LEDs per fan |
Pump Head RGB | 16 RGB LEDs | 33 CAPELLIX RGB LEDs | 24 RGB LEDs |
Tubing Length | 400 – 450mm | 380mm | 380mm |
LCD Display | X | X | YES |
Lighting Controller | X | COMMANDER CORE | COMMANDER CORE |
AMD Compatibility | AM5, AM4, sTR4, sTRX4 | AM5, AM4, AM3+/FM, sTR4, sTRX4 | AM5, AM4, sTR4, sTRX4 |
Intel Compatibility | LGA 1700, 1200, 115X, 2066 | LGA 1700, 1200, 115X, 2066 | LGA 1700, 1200, 115X, 2066, 2011 |
MSRP | $139.99 – $179.99 | $149.99 – $229.99 | $259.99 – $309.99 |
AF ELITE Series fans also launch today as standalone offerings. Available in either black or white and in 120mm or 140mm sizes, AF ELITE fans take advantage of powerful CORSAIR AirGuide technology and ultra-quiet fluid dynamic bearings to deliver robust, concentrated airflow. For cooling that keeps your system performing at its best, take AF ELITE fans for a spin.
The H100i RGB ELITE, H115i RGB ELITE, and H150i RGB ELITE combine compelling aesthetics, ease of use, and essential cooling suited for nearly any system. Included AF ELITE PWM fans deliver a torrent of powerful airflow with minimal noise, thanks to CORSAIR AirGuide technology and a fluid dynamic bearing. Each new AIO cooler efficiently disperses heat through a high-surface-area radiator in a size that fits your build – either 240mm, 280mm, or 360mm, respectively. A refined, contemporary pump head design emanates lighting from 16 individually addressable RGB LEDs, controlled with the rest of your RGB setup via powerful CORSAIR iCUE software for stunning synchronized effects and integrated lighting with select games.
The H100i RGB ELITE, H115i RGB ELITE, and H150i RGB ELITE will be compatible with AM5, the next-generation AMD motherboard socket, which uses the same cooler bracket as AM4. This means there’s no need to purchase new brackets or replace your RGB ELITE cooler when upgrading your system to the upcoming AM5 platform. The RGB ELITE Series also supports LGA 1700 out of the box for cooling the latest Intel 12th Generation Core processors, as well as legacy support for LGA 1200, LGA 115x, LGA 2066, and AM4.
Installing your RGB ELITE CPU Cooler is easy and intuitive thanks to its modular, tool-free mounting bracket and conveniently placed USB Type-C power and fan harness for a quick connection. An extended five-year warranty guarantees your cooler will last throughout your processor’s lifespan.
Source: Corsair
