MSI has announced its custom AMD Radeon RX 6950 XT, Radeon RX 6750 XT, and 6650 XT graphics cards. The Radeon RX 6950 XT GAMING X TRIO 16G features a boost clock of up to 2,454 MHz, TRI FROZR 2 cooling solution with TORX Fan 4.0, RGB, metal backplate, custom PCB with additional fuses for added protection, and an anti-bending strap and support bracket to prevent sag or bending. It has been spotted with a price of $1099.99.
Specifications
- Model Name: Radeon RX 6950 XT GAMING X TRIO 16G
- Graphics Processing Unit: Radeon RX 6950 XT
- Interface: PCI Express Gen 4
- Core Clocks: Boost: Up to 2454 MHz (Boost), Up to 2244 MHz (Game)
- Memory Speed: 18 Gbps
- Memory: 16GB GDDR6
- Memory Bus: 256-bit
- Output: DisplayPort x 3 (v.1.4a), HDMI x 1 (Supports 4K@120Hz/8K@60Hz and VRR as specified in HDMI 2.1)
- HDCP Support: Y
- Power consumption: 340 W
- Power Connectors: 8-pin x 3
- Recommended PSU (W): 850 W or greater
- Card Dimension(mm): 325 x 140 x 55mm
- Weight (Card / Package): 1605 g / 2434 g
- DirectX Version: Support 12 Ultimate
- OpenGL Version: Support 4.6
- Maximum Displays: 4
- VR Ready: Y
- Digital Maximum Resolution: 7680×4320
Source: MSI
