MSI has shared a press release detailing its initial lineup of motherboards leveraging AMD’s brand-new X670 and X670E chipsets. They comprise the MEG X670E GODLIKE, MEG X670E ACE, MPG X670E CARBON WIFI, and PRO X670-P WIFI, all of which include support for Ryzen 7000 Series processors. The X670E models support PCIe 5.0 through both the PCIe slot and M.2 slot, while the X670 option supports PCIe 5.0 through the M.2 slot exclusively. MSI plans to launch its first X670 and X670E motherboards this fall.
The Revelation of Legend – MEG Series
Our MEG Series have more features than ever on our MEG X670E GODLIKE and MEG X670E ACE motherboards. The MEG Series adopt E-ATX PCB size and have up to 24+2 VRM phases with 105A Smart Power Stage. They are cooled by a Stacked fin array design heatsink as a well as a heat-pipe to dissipate heat effectively while maintaining at peak performance. There is also a MOSFET baseplate for more heat dissipation for the VRM while the Metal backplate is there to help protect the PCB as well as keeping the rigidity of the board. The MEG Series motherboards are equipped with up to 4 onboard M.2 slots including 1 M.2 PCIe 5.0 x4 slot and a M.2 XPANDER-Z GEN5 DUAL add-on card inside the box for 2 additional PCIe 5.0 x4 M.2 slots for ultimate experience.
Be Ahead, Pop Your Style – MPG Series
The MPG Series enjoys extraordinary upgrades for the new AMD platform. With the use of carbon black color scheme, MPG X670E CARBON WIFI is steadier than before. This motherboard features 2 PCIe 5.0 x16 slots and 4 M.2 slots that are split into 2 M.2 PCIe 5.0 x4 and 2 PCIe 5.0 x4. It comes with 18+2 VRM power phases with 90A and cooled by Extended heatsink design. Featured the latest specifications, you will definitely be satisfied with a unique aesthetic finish from the Chipset Heatsink to the VRM Heatsink on the MPG X670E CARBON WIFI.
Business Elegance – PRO Series
The PRO Series might be the best in popularity for enterprises and creators. With the 14+2 Phases Duet Rail Power System and dual 8-pin CPU power connectors, the PRO X670-P WIFI will tackle any task with ease. The PRO Series does come equipped with 1 M.2 PCIe 5.0 x4 slot, 2.5G LAN and Wi-Fi 6E solution, which can speed through your work with breeze. The linear design matches your office or studio in every possible way for a more unified look.
Source: MSI
