Euro PC Case Features Big Radiators on Each Side Panel
Image: Regner Cooling System
Regner has introduced a new PC case (“INDIVIDUAL”) that has huge radiators built into each side panel. They are made with anti-corrosion materials and are connected to an EKWB EK-Loop DDC 4.2 PWM pump. It has 3x be quiet! Silent Wings 3 140 mm fans (two in the front, one for exhaust). The case supports up to E-ATX motherboards and graphics cards up to 13.385 inches in length. At roughly 46 pounds, the case is not light, and it is priced at 1,900 Euros (~$1,986.49). Other features include 1x USB 3.0 and 1x USB-C ports, and LED lighting in the front. Overclocker der8auer reviewed the case on his channel and explained that the high price is due to the case and parts being manufactured in Germany.
Simple design and modular structure – the Cooling System INDIVIDUAL is an excellently equipped high-tech case with integrated water cooling and a real eye-catcher!
The high-quality aluminum construction with huge aluminum radio gates combines stylish aesthetics and practical features. The fan speed and the cooling capacity can be controlled dynamically and optimally adapted to the requirements. The airflow is improved and excellent heat dissipation is guaranteed by specially designed ventilation channels including removable radiators.
Technical specifications
Model: Cooling System INDIVIDUAL
Colour:  Individual painting according to RAL color number
Format: E-ATX / ATX / Micro ATX / Mini ITX
Dimensions:  length: 470mm / width: 240mm / height 480mm
Weight: 21kg
Material: aluminum
I/O panel: 1x USB 3.0 / 1x USB Type-C / 2x audio 3.5mm / power button
Drive capacity: 2x 2.5″ internal
Fan configuration: 2x front and 1x rear (be quiet! Silent Wings 3 140 mm PWM )
Graphics card: max. 34cm long
Water cooling: 2x aluminum radiators (anti-corrosion) /1x pump (EKWB EK-Loop DDC 4.2 PWM) including fittings G1/4 and soft tubs 10/16
Power supply: ATX width: 150 mm / height: 86 mm / length: max. 180mm
Features: Removable radiators / 360° access / Front LED lighting
Source: Regner Cooling System (via Tom’s Hardware)
