Cooler Master Launches CMP 520 and CMP 320 ARGB Cases
Image: Cooler Master
Cooler Master has launched two new cases that feature a unique front design.
Listed this week on the manufacturer’s website, the CMP 520 and CMP 320 are two new cases that can fit up to ATX and Micro ATX sized motherboards, respectively. Both feature a front panel “inspired by asymmetrical crystal formations,” enabling a bit of an aggressive look, as well as other features that include 120 mm ARGB fans, a breathable power supply shroud, and full black coating.
It doesn’t appear as if Cooler Master has shared the official pricing for its CMP 520 and CMP 320 cases, but they shouldn’t be too expensive, as speculated by Tom’s Hardware, which spotted the new listings.
Based on the design language, we can estimate these cases to be cheaper models with a price of around $80 to $120, depending on the price of the fans. This should put them in competitive distance of other popular cases such as the Phanteks P series, G series, Fractal Design Meshify 2, and NZXT H5 series, to name a few.
CMP 520
  • Three 120mm ARGB Fans Included
  • Mesh Geode Front Panel
  • Versatile Cooling Options
  • Full Black Coating & PSU Cover
  • Breathable Power Supply Shroud
Model NumberCP520-KGNN-S00
Exterior ColorBlack
Materials ExteriorSteel, Plastic
Materials – Left Side PanelTempered Glass
Dimensions (LxWxt H)439 X 204 x 463mm (Incl. Protrusions). 432 X 204 x 448mm (Excl. Protrusions)
Volume43.34L (Exlc. Protrusions)
Motherboard SupportMini ITX, Micro ATX, ATX
Expansion Slots7
2.5″ /3.5″ Drive Bays (Combo)2
2.5″ Drive Bays2
I/O Panel1x USB 3.2 Gen 1 Type-A, 1x USB 2.0, 1x 3.5mm Headset Jack (Audio+Mic)
ARGB ControllerCF120P (integrated with fan) or M/B
Pre-installed Fans – Front1x CF120P ARGB + 2x CF120S ARGB
Fan Support Top2x 120mm, 2x 140mm
Fan Support Front3x 120mm, 2x 140mm
Fan Support Rear1x 120mm
Radiator Support – Top120 / 240mm* (*RAM height below 35mm)
Radiator Support – Front120mm, 140mm, 240mm, 280mm
Radiator Support – Rear120mm
Clearance – CPU Cooler161mm
Clearance PSU160mm
Clearance GFX350mm (w/o front fans & radiator)
Cable Routing18.5mm
Dust FiltersTop. Bottom
Power Supply SupportBottom Mount, ATX
Warranty2 years
SeriesCMP Series
SizeMid Tower
CMP 320
  • Two 120mm ARGB Fans Included
Model NumberCP320-KGNN-S00
Exterior ColorBlack
Dimensions (L x W x H)445.5x 204 x 425mm (Incl. Protrusions). 431.8x 204 x 410mm (Excl. Protrusions)
Volume38.52L (Excl. Protrusions)
Expansion Slots4
2.5″ 13.5″ Drive Bays (Combo)2
2.5″ Drive Bays2
Pre-installed Fans – Front1x CF120P ARGB + 1x CF120S ARGB
Fan Support Front2x120mm/3x120mm (*Installed inside the case only)
Radiator Support – Top120mm, 140mm, 240mm. 280mm (*Recommend AIO tubes face rear to avoid interference)
Radiator Support – Front120mm, 240mm
Clearance – CPU Cooler163.5mm
Clearance PSU160mm
Clearance GFX365mm (without front fans & radiator)
Cable Routing16.5mm
Warranty2 years
SeriesCMP Series
SizeMini Tower
Cooler Master is also offering two variants of these cases in the form of the CMP 520L and CMP 320L. The only difference seems to be that they don’t include 120 mm ARGB fans.
Source: Cooler Master
