Lian Li SP850 White 850W SFX Power Supply Review
Transient Testing
For those of you that are curious as to some of the reasoning and equipment behind our PSU testing program here at TheFPSReview, we have put together an introduction for you that shares a lot of the behind-the-scenes of the program. This program is based on what the author developed at [H]ardOCP and utilizes the equipment bequeathed to the author by Kyle Bennett. The testing we are conducting today is exactly as described in that document and will continue with our Transient Testing.
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the Lian Li SP850 at 45c. This makes Test #1 equal to 220W by loading the 12v rail to 16a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~320mV drop on the 12v rail and ~45mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~40mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the Lian Li SP850 at 45c. This makes Test #2 equal to 429W by loading the 12v rail to 32a, the 5v rail to 4a, the 3.3v rail to 3a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~220mV drop on the 12v rail and ~40mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~35mV drop.
The Transient Load Tests results for the Lian Li SP850 are passing and good. In today’s testing, the SP850 saw the loaded 12v rail post a peak change of ~320mV and the loaded 5v rail post a peak change of ~45mV. The unloaded 5v peak change during the 12v load was ~40mV. Those numbers are passing in an absolute sense and good when it comes to the 5v rail but not quite as good as for the 12v rail. However, when we look at comparable units we see that this unit bests the Cooler Master V850 SFX Gold WHITE Edition even with the 12v results being what they are today. Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
Paul Johnson
