Lian Li SP850 White 850W SFX Power Supply Review
DC Output Quality
For those of you that are curious as to some of the reasoning and equipment behind our PSU testing program here at TheFPSReview, we have put together an introduction for you that shares a lot of the behind-the-scenes of the program. This program is based on what the author developed at [H]ardOCP and utilizes the equipment bequeathed to the author by Kyle Bennett. The testing we are conducting today is exactly as described in that document and will continue with our examination of the DC Output Quality.
Control Test Graphing
This image is the blank background control test on an unused connector from our SM-8800 during the testing of the Lian Li SP850. This lets us determine what the background noise looks like during testing.
120v Input
100v Input
Test #1 is equal to approximately 25% of the rated capacity of the Lian Li SP850 at 45c. This makes Test #1 equal to 220W by loading the 12v rail to 16a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a. The SP850 is starting off in decent shape. The 12v rail is peaking at ~15mV of ripple/noise while the minor rails are peaking at ~10mV of ripple/noise or less.
120v Input
100v Input
Test #2 is equal to approximately 50% of the rated capacity of the Lian Li SP850 at 45c. This makes Test #2 equal to 429W by loading the 12v rail to 32a, the 5v rail to 4a, the 3.3v rail to 3a, the +5vsb to 2a, and the -12v to 0.3a. Test #2 sees no real changes as the 3.3v and 5v rails are coming in at ~10mV of ripple/noise or less while the 12v rail is coming in at ~20mV of ripple/noise.
120v Input
100v Input
Test #3 is equal to approximately 75% of the rated capacity of Lian Li SP850 at 45c. This makes Test #3 equal to 631W by loading the 12v rail to 48a, the 5v rail to 6a, the 3.3v rail to 4a, the +5vsb to 2a, and the -12v to 0.3a. Test #3 sees the 12v rail coming in at ~30mV of ripple/noise while the minor rails are coming in at ~15mV of ripple/noise for the 5v rail and ~10mV for the 3.3v rail.
120v Input
100v Input
Test #4 is equal to approximately 100% of the rated capacity of the Lian Li SP850 at 45c. This makes Test #4 equal to 842W by loading the 12v rail to 68a, the 5v rail to 2a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a. In the final regular test, we see the 12v rail peaking at ~30mV of ripple/noise while the 5v rail is peaking at ~10mV of ripple/noise and the 3.3v rail is peaking at less than ~1omV of ripple/noise.
Torture Test
The Torture Test is equal to approximately 80% of the rated capacity of the Lian Li SP850 at 45C. This makes the Torture Test equal to 671W by loading the 12v rail to 50a, the 5v rail to 7a, the 3.3v rail to 5a, the +5vsb to 2a, and the -12v to 0.3a. At the end of the Torture Test, we see the 12v rail peaking at ~30mV of ripple/noise while the 5v rail is peaking at ~15mV of ripple/noise and 3.3v rail is peaking at ~10mV of ripple/noise.
DC Output Quality Summary
The overall DC Output Quality of the Lian Li SP850 is excellent. The ripple/noise values started the day off in good shape and only changed slightly during our testing. Overall, the SP850 ended up posting a peak trace amplitude on the 12v rail of ~30mV followed by ~15mV on the 5v rail and ~10mV on the 3.3v rail. None of these values exit the ATX12v specification limits or even approach those limits. Indeed, the worst value only hit ~30% of the ATX12v specification limit. Now in a relative sense, this unit trailed the Cooler Master V850 SFX GOLD WHITE just barely. Overall then, this unit did well. Let’s move on now and see how all of this wraps up!
Paul Johnson
