GIGABYTE Z790 AORUS XTREME and MASTER Motherboards Used XMP 3.0 To Overclock T-FORCE DELTA RGB DDR5 Memory to 7950 MHz
Image: GIGABYTE
GIGABYTE has shown off how well its Z790 AORUS XTREME and MASTER motherboards can overlock the TEAMGROUP T-FORCE DELTA RGB DDR5 7200 memory. DDR5 is already maturing to allow the fastest speeds ever seen on home PCs without using exotic cooling such as liquid nitrogen but now we’re seeing it can be reliably pushed further on air with the right components. GIGABYTE used an Intel Core i9-13900K clocked at 5.5 GHz, and an updated XMP 3.0 profile, to overclock the 32 GB DDR5-7600 CL36 1.45V kit (a variation of the 7200 memory) up to 7950 MHz.
Image: GIGABYTE
Image: GIGABYTE
Press Release
GIGABYTE TECHNOLOGY Co. Ltd, a leading manufacturer of motherboards, graphics cards, and hardware solutions, today revealed the breakthrough DDR5 performance of XMP DDR5-7600 and O.C. performance to DDR5-7950 under fan cooling on Z790 AORUS XTREME and MASTER motherboards with TEAMGROUP gaming modules T-FORCE DELTA RGB DDR5 7200 memory. Featuring Shielded Memory Routing of SMD memory DIMM, exclusive DDR5 overclocking BIOS setting, top-quality components, and enhanced design from hardware to firmware on motherboards, this performance proves GIGABYTE’s strong leading role in product quality and performance.
To unleash the ultimate DDR5 performance, GIGABYTE Z790 AORUS XTREME and MASTER implement new generation Shielded Memory Routing design. By optimizing memory trace width, length, and style from HPC simulation to actual implementation, overall impedance is lowered between CPU memory controller and memory modules. Further with low signal-loss PCB, signal loss inside PCB and external interference are greatly reduced which can maintain high-speed DDR5 signal transmission to achieve higher DDR5 speed. In addition, the abundant BIOS setting of DDR5 Memory Upgrade and XMP 3.0 User Profile lead to the breakthrough performance of XMP DDR5-7600 and DDR5-7950 O.C. under fan cooling with T-FORCE DELTA RGB DDR5 7200 memory. The detailed memory information is listed in the memory support list of the motherboard.
https://www.gigabyte.com/Motherboard/Z790-AORUS-MASTER-rev-10/support#support-memsup
This remarkable memory performance on Z790 AORUS XTREME and MASTER with T-FORCE DELTA RGB DDR5 7200 memory is only the beginning of GIGABYTE’s supreme-performance motherboards.
Source: GIGABYTE
