PNY GeForce RTX 3060 12GB XLR8 Gaming REVEL EPIC-X RGB Single Fan Edition Video Card Review
Test Setup
Bench hardware is listed below.  More information on our GPU testing can be found here.
We are using the motherboard’s current default BIOS settings on the latest official release BIOS.  We have enabled PCI-Express Resizable BAR in the motherboard BIOS.  This means we are utilizing Resizable BAR on NVIDIA GPUs and AMD Smart Access Memory on AMD GPUs in all of our testing.  We have enabled DOCP in the BIOS for the memory.
We are using a fresh install of Windows 11 Pro with the latest Windows Updates, and drivers installed including the latest chipset drivers from AMD.  We are using the “Best Performance” power profile in Windows Settings.  We have Hardware Accelerated GPU Scheduling at the default setting, which is ENABLED.  VBS is DISABLED and Game Mode is ENABLED.
Performance
Efficiency
Cooling
The PNY GeForce RTX 3060 12GB XLR8 Gaming REVEL EPIC-X RGB Single Fan Edition Video Card performs very well for its size, and size is the primary benefit of this video card. You can put it into small cases and builds, and enjoy a good gameplay experience, so the value of this card is rated high. We knock it down a couple of notches on performance overall, because it is outperformed by the competition, in a larger footprint. The efficiency and cooling on this video card are top-notch, and this small video card, keeps itself well cooled for gaming.
