The AOC CU34G2XP is an update to the previously launched CU34G2X 34-inch ultrawide VA panel with upgraded features. The former display was launched three years ago. DisplaySpecifications has reported the 1500R curvature also remains the same along with a resolution of 3440 x 1440, while the refresh rate has been bumped up to 165 Hz from 144 Hz. Brightness has also been increased to ~350 nits.
AOC CU34G2XP Specifications
- Resolution: 3440×1440
- Refresh Rate: 165 Hz
- Panel Type: VA
- Panel bit depth: 8-bit (16.7 million colors)
- Size: 34-inch
- Curvature: 1500R
- Typical Brightness: 350 nits
- Contrast Ratio: 4000:1
- Color Gamut: 124% sRGB, 93% of DCI-P3, 102% NTSC (1953)
- Viewing angle: 178 degrees
- VRR Support: AMD FreeSync via Adaptive-Sync
- Display connectors: 2x DP 1.4 (up to 165 Hz), 2x HDMI 2.0 (up to 120 Hz)
- USB: 4x USB 3.2 Gen 1 Type-A, 1x Type B
- Headphone jack: 3.5mm
- VESA compatibility: 100 x 100 mm
- Low Bluelight mode: yes
- Flicker-free technology: yes
- Motion Blur Reduction (MBR)
- Frame Counter
- Picture-in-Picture
- Picture-by-Picture
- Stand features: Up to 130 mm height adjustment, tilt+swivel adjustment
- Power Consumption: ~52 Watts
Pricing for the AOC CU34G2XP has not been announced but its predecessor still retails overseas for RMB 1799, or roughly $250, so it could be at a relatively similar price point.
