Noctua has launched the NM-SD1 and NM-SD 2, two new high-quality screwdrivers designed for installing Noctua CPU coolers that use Torx-based SecuFirm2+ mounting systems and cross-recess-based SecuFirm and SecuFirm2 mounting systems, respectively.
Noctua NM-SD1 SecuFirm2+ Torx T20 Screwdriver
- High-quality screwdriver for installing Noctua CPU coolers that use Torx based SecuFirm2+ mounting systems
- Easier to operate and even more durable thanks to the reduced cam-out of the Torx T20 drive
- 150mm long shaft makes it easy to reach the mounting screws of large heatsink models
- Magnetic tip reduces the risk of dropping screws, especially when space is tight and screws are hard to reach
- Large, convenient grip: comfortable to operate and helpful for applying pressure to spring-loaded mounting screws
Noctua NM-SD2 SecuFirm2 Phillips PH2 Screwdriver
- High-quality screwdriver for installing Noctua CPU coolers that use cross recess based SecuFirm and SecuFirm2 mounting systems
- Compatible with many popular Noctua heatsinks such as NH-D15(S), NH-D14, NH-U14S, NH-U12A, NH-U12S, NH-U12P, NH-U9B, NH-U9S, NH-C14(S), NH-L12(S), NH-L9, etc.
The NM-SD2 is unavailable on Amazon at the time of this posting, but the former is in stock and listed for the relatively cheap price of $9.90.
The NM-SD1 is a high-quality Torx T20 head screwdriver that is ideal for use with Noctua’s SecuFirm2+ mounting systems. Its 150mm long shaft makes it easy to reach the mounting screws of large CPU coolers and thanks to its magnetic tip, fixing screws in space-constrained environments such as tightly packed ITX builds is a breeze. Featuring a large, comfortable grip, the NM-SD1 is the tool of choice for power users who operate SecuFirm2+ systems.
The NM-SD2 is a high-quality Phillips PH2 head screwdriver that is ideal for use with Noctua’s cross recess based SecuFirm and SecuFirm2 mounting systems. Its 150mm long shaft makes it easy to reach the mounting screws of large CPU coolers and thanks to its magnetic tip, fixing screws in space-constrained environments such as tightly packed ITX builds is a breeze. Featuring a large, comfortable grip, the NM-SD2 is the tool of choice for power users who operate Phillips type SecuFirm and SecuFirm2 systems.
Noctua introduced NA-IS1 inlet spacers for suction applications and the NA-SAVG2 gasket set in November.
