MONTECH Launches ATX 3.0 and PCIe 5.0 Ready TITAN GOLD Power Supplies
Image: MONTECH
MONTECH, a leading PC component and peripheral brand, has announced its ATX 3.0 and PCIe Gen 5.0 (12+4-pin 12VHPWR connector) ready TITAN GOLD series of power supplies for NVIDIA’s GeForce RTX 40 Series GPUs, featuring high-quality components such as 100% Japanese 105°C capacitors and silent operation via an FDB (fluid dynamic bearing) fan that supports zero RPM mode under low-load situations.
The TITAN GOLD series is available in four models, all of which are 80 Plus Gold and Cybernetics Gold certified, according to a press release and promotional materials shared by MONTECH:
  • TITAN GOLD 750W: $139
  • TITAN GOLD 850W: $149
  • TITAN GOLD 1000W: $169
  • TITAN GOLD 1200W: $199
ATX 3.0 & PCIe 5.0 Ready
The TITAN GOLD is ATX 3.0 and PCIe Gen 5.0 ready, and is essential for next-generation GPUs such as the NVIDIA GeForce RTX 40 series. The PCIe Gen 5.0 includes the 12+4 pin 12VHPWR connector, which is designed to better communicate with the newer GPUs and delivers up to 600W, and is able to handle up to 200% excursions (spikes in power draw).
Image: MONTECH
100% Japanese Capacitors & Ripple Noise Under 18mV
Equipped with 100% high-quality Japanese capacitors rated at 105°C, while using advanced half-bridge, LLC and Synchronous Rectifier (SR) technology, the TITAN GOLD has excellent signal stability and power efficiency. It also uses DC-to-DC conversion for tight voltage regulation of 1.8% and minimizes ripple noise to under 18mV, avoiding unbalanced power loads.
Quiet & Efficient Operation
The TITAN GOLD is equipped with a quiet 135mm fluid dynamic bearing (FDB) fan with zero RPM mode until it reaches 40% loading. Afterwhich, the maximum noise level of the TITAN GOLD reaches 27 dBA at 1400 RPM. The TITAN GOLD is also 80PLUS Gold and Cybenetics Gold certified for maximum efficiency of more than 92%, for independent testing and verification of the lower energy consumption and higher efficiency of the power supply.
MONTECH has confirmed that its TITAN GOLD power supplies are now available at Amazon.
“MONTECH thrives on providing top-performance products at competitive pricing for the PC gaming market and has quickly become a top-seller in the USA and Taiwan markets,” wrote the company, which was established in 2016.
Image: MONTECH
