Samsung Develops Industry’s First 12-Nanometer-Class DDR5 DRAM
Image: Samsung Electronics
Samsung Electronics has announced the development of its 16-gigabit (Gb) DDR5 DRAM built using the industry’s first 12-nanometer (nm)-class process technology, as well as the completion of product evaluation for compatibility with AMD.
“Our 12nm-range DRAM will be a key enabler in driving market-wide adoption of DDR5 DRAM,” said Jooyoung Lee, Executive Vice President of DRAM Product & Technology at Samsung Electronics. “With exceptional performance and power efficiency, we expect our new DRAM to serve as the foundation for more sustainable operations in areas such as next-generation computing, data centers and AI-driven systems.”
“Innovation often requires close collaboration with industry partners to push the bounds of technology,” said Joe Macri, Senior VP, Corporate Fellow and Client, Compute and Graphics CTO at AMD. “We are thrilled to once again collaborate with Samsung, particularly on introducing DDR5 memory products that are optimized and validated on ‘Zen’ platforms.”
This technological leap was made possible through the use of a new high-κ material that increases cell capacitance and proprietary design technology that improves critical circuit characteristics. Combined with advanced, multi-layer extreme ultraviolet (EUV) lithography, the new DRAM features the industry’s highest die density, which enables a 20 percent gain in wafer productivity.
Leveraging the latest DDR5 standard, Samsung’s 12nm-class DRAM will help unlock speeds of up to 7.2 gigabits per second (Gbps). This translates into processing two 30 gigabyte (GB) UHD movies in just one second.
The new DRAM’s exceptional speed is matched by greater power efficiency. Consuming up to 23 percent less power than the previous DRAM, the 12nm-class DRAM will be an ideal solution for global IT companies pursuing more environment-friendly operations.
Samsung has confirmed that mass production of its 12-nanometer-class DRAM, which it has described as cutting-edge, will begin in 2023.
In October, the company announced that it had completed validation of LPDDR5X DRAM at an operating speed of 8.5 Gbps on Snapdragon mobile platforms, unlocking new markets for LPDDR memory.
