Rumored Specs and Images for NVIDIA 24 GB/24 Gbps GeForce RTX 4090 Ti and 800W/48 GB Titan Graphics Cards Emerge
Image: MegaSizeGPU
It has been an interesting weekend with rumored specs and images for what could be NVIDIA’s next round of flagship graphics cards. For some time there have been rumors about a new Titan featuring a quad-slot design with a triple fan solution, monstrous heatsink, and equally frightening TBP and now it appears that something now nicknamed “The Beast”, aka possibly the RTX Titan ADA, could be happening after all. MegaSizeGPU posted the following images at the beginning of the weekend.
RTX Titan ADA?
Well-known leaker kopite7kimi has previously posted rumored specs for a potential RTX Titan. It was said to use a PG137-SKU0/AD102-450-A1 GPU, have 18,176 CUDA cores,48 GB/24 Gbps GDDR6X memory, and up to a whopping 800 Watts of total board power which would need 2x 12VHPWR connectors. Another leaked image/rumor shows a quad slot design heatsink and it’s been claimed that this card will feature a triple fan cooling solution. At the time this heatsink was said to be NVIDIA’s 900 Watt solution which would align with the other rumors about an 800 Watt TBP card.
Image: Chiphell
More GeForce RTX 4090 Ti Details
Image: Chiphell
There have also been rumored specs and images of a new, but familiar, heatsink design for the follow-up to the GeForce RTX 4090. Previously, in May, images showed a bracket and what appeared to be a similar cooling solution as seen with other Ampere and ADA cards. It is now claimed that the GeForce RTX 4090 Ti will feature a PG136/139-SKU310 GPU, 18,176 CUDA Cores, 24 GB/24 Gbps GDDR6X memory, and around 600 Watts of total board power while keeping with a single 12VHPWR connector. These alleged specs align with others that had been posted by another user in October 2022 who also added that NVIDIA was already setting aside its best AD102 GPUs for the RTX 4090 Ti.
AD102 and NVIDA’s 30th Anniversary
Both of these rumored cards are said to have the same amount of CUDA cores vs. the 16,384 found on the RTX 4090 AD102. That same die has 512 (4th Gen) Tensor cores and 128 (3rd Gen) RT cores. It has not been leaked as to what a Titan/RTX 4090 Ti could have but the known full specs for the AD102 are 576 Tensor cores and 144 RT cores.
At the moment, it makes little to no sense why NVIDIA would want to release either of these potentially new flagship cards as there is literally zero competition in this market sector. However, the Titan brand has been absent since the Turing generation and it has been speculated that NVIDIA could be planning to bring it back as part of the company’s 30th-anniversary celebration in April. NVIDIA will be doing a GTC keynote in March where such an announcement could happen.
Discussion (17 replies)
Riccochet
Riccochet 👍 4
800W Titan, now comes with Stark Industries ARC Reactor
So are we thinking the Titan card is going to start at 3000?
LazyGamer
LazyGamer 👍 3
Not sure I've seen a PSU with two 600W 12VHPWR connectors yet?
Grimlakin 👍 2
Yea I know hearing about this one makes me think my 1300 wat platinum+ PSU might not be enough... I mean I look forward to Jay2c and LTT and Steve running these through their paces and all.. but a full built high end system to feed one of these cards is going to be a requirement. And I just worry about having to set up my office so monitors can be on a difference circuit that my tower.
Not to mention needing to find a 2000 watt UPS.
Peter_Brosdahl 👍 1
There are a couple. I can't remember off the top of my head but literally a couple that I'm aware of. I think Galax and one of the major PSU manufacturers.
Peter_Brosdahl 👍 1
Yeah and probably a dedicated circuit. As is, I see the lights in a room with a 1200 W PSU flicker every time it gets turned on. I admit, this is getting ridiculous.
Mo power is all good and all. But efficiency is a thing and needs to be explored. With todays technology I don't understand outside of heavy compute uses... why a system would actually NEED over 1000 watts of power. I have a 1300 watt power supply sure. Looking at my UPS I'm only drawing 270 watts. I get close to 450ish watts pulled when gaming maybe somewhat higher. Benchmarks take the most but I'm not even going to mess with that. So if I'm PULLING lets be nice and say 500 watts.. at 90% efficiency that means I'm only using 450 watts for some intense gaming. that's including my monitors and all that are on the UPS. All of my peripherals and everything. So really that's most likely a bit less. But you get the idea.
So if that is the case... I'm using a LOT less power day to day that I thought I was to be honest and this power supply should last a good long while.
Out of curiosity, what is YOUR power draw dear reader and forum member. Can you launch your UPS app and see what you're pulling down forum surfing and loading up a game?
The game I used to test RQ was seven days to die because it feels unoptimized still.
Peter_Brosdahl 👍 1
I'm in the midst of getting another UPS as my rigs have been exceeding the one(s) I have but I can tell you that the 4090 is way more efficient than the 3090 Ti for what it does and averages 300-400, most of the time. I have seen 450-500 but its pretty rare that's sustained. Same for the 5800X3D vs 3700X. It manages 55-65W most of the time while my testing with the 3700X showed 70-90W. I estimate both rigs are pulling 500-600 most of the time but with different performance levels. I test with CB 2077, Witcher Enhanced, Metro Exodus Enhanced, RE Games (when IQ is cranked and VRAM loads up 18+GB, I've seen the 4090 really pull upwards and over 500W), Horizon Zero Dawn, SOTTR. I use all of these because of RT and/or DLSS options. Just got Dead Space and will report more on that but I barely had enough time to to anything with it this weekend.
LazyGamer
LazyGamer 👍 1
1300W should easily cover it, assuming it's built to the appropriate standards. Mostly because you'd be hard pressed to get that much sustained power draw out of a single consumer-level CPU and GPU set.
Grimlakin 👍 2
I agree but... 800 WATTS for a just for a GPU is kind of bonkers. We need a shift back to efficiency and performance. Not just performance at any cost.
DrezKill
DrezKill 👍 1
If it comes with a for-realz Stark Arc Reactor, then it will definitely be worth the price. At that point I'm buying it more for the reactor than the card.
My desk lamp and the Verizon FiOS modem+router combo device (G3100) only draw about 2W from the UPS (well the G3100 was mostly idle at the time, there wasn't a lot of network activity going on). My 3 monitors use about 100W together, my 5.1 speaker system adds about 20W (well when not playing anything), and my NAS uses about 30W. The PC itself, when idle (or during light usage like web browsing and word processing), uses between 170-200W. When gaming with an RTX 3090 (MSI Suprim X) I recently got, the highest I've seen reported by the UPS software so far was just under 800W. I haven't seen it crack 800W yet. My PSU is a Seasonic-built Corsair 850W unit I bought in 2010 (and which has been used all day almost every day since, so it has a lot of hours on it), and my UPS can handle 900W max.
This is not the highest I've seen, but close to it:
The problem will come in the summer, cuz the window A/C unit (which I never run above low power) is on the same outlet as the UPS. I see some fuse-trippin' in my future... Also both entertainment centers (one for HDTV consoles and one for CRT consoles) are also on the same circuit. I probably shouldn't run the 3090 at or near full load and turn on the PS3 at the same time! The HDTV and the PS3 are the biggest contributors to heat in the room after the PC (and the PS3 is by far the loudest thing in the room, even louder than the A/C unit!). However if I am using the PC and gaming on the 3090 then I obviously wouldn't also be gaming on a console with the HDTV on. So at this point my concerns are PC+A/C or HDTV-and-consoles+A/C. PC+A/C+HDTV-and-a-console all at the same time would never happen. Well except if a friend or family member comes by to chill in the summer, and one of us is gaming on the HDTV and the other on the PC, all while the A/C is running. But I'll cross that bridge the next time I find myself in such a situation.
Brian_B 👍 1
Efficiency is important. But there still is a ceiling on power draw, no matter how efficient you can be.
Most residential circuits cap at 15A (about 1700W give or take). Going beyond that and you are looking at commercial / semi-pro applications that can run dedicated circuits or higher voltage.
Makes me lament the loss of the lower tiers more so than get excited that there is another card out there with no great use cases other than marketing
DrezKill
DrezKill 👍 1
[IMG alt="RTX3090_Witcher3_UPS_Power_Usage_Pic2.png"]https://forums.thefpsreview.com/attachments/rtx3090_witcher3_ups_power_usage_pic2-png.2322/[/IMG]
New record:
(The NAS was not running when this screenshot was taken, so its power usage is not factored in here.)
Niner51
Niner51 👍 1
It's even hard to find an ATX 3.0 PCIE Gen 5 PSU at all right now.
LazyGamer
LazyGamer 👍 2
We're at least seeing more models announced from a wider variety of manufacturers - and MSI seemed to have decent availability.
Of course, there's also a ~50% premium associated with these units so it's best to hold off unless a unit needs replacing for whatever reason, or a new build would benefit from one.
