PowerColor Teases Its Next Liquid Devil Graphics Card Which Is Believed to Be a Radeon RX 7900 XTX
Image: PowerColor
PowerColor has teased an image hinting that its next Liquid Devil graphics card release could be right around the corner. With PowerColor’s flagship last release being the Liquid Devil AMD Radeon RX 6900 XT Ultimate, which was used by an overclocker to break a world record, it is believed that the next card will use AMD’s current flagship GPU, the Radeon RX 7900 XTX.
As seen in the image there are the Liquid Devil and EK logos. In the past EKWB has provided a custom acrylic water block that features RGB lighting and has a nickel-plated copper base with a nickel-plated finish. It is expected that this forthcoming card would also have 3x 8-pin power connectors and possibly a 12+3+2 phase VRM design (per VideoCardz), although it is worth noting that PowerColor announced in December 2022 that its Hellhound series versions of the 7900 XTX and XT would feature a premium 14-layer PCB and 20 VRMs.
Even though a Liquid Devil Radeon RX 7900 XTX offering is sure to get the attention of those wanting the best AMD currently has to give it is likely that a 7900 XT Liquid Devil will also be released just as PowerColor did for both the AMD Radeon RX 6900 XT and RX 6800 XT. It is not known if PowerColor will use the EK-Quantum Vector² Water Block for PowerColor Red Devil AMD Radeon RX 7900 XTX or if it and EK will partner for a more customized design. Pricing for the XTX version could be high as currently, the only other similar offering is the ASROCK Radeon RX 7900 XTX 24GB AQUA OC which, while out of stock, has been spotted as high as $1,449 on Newegg. It is believed that PowerColor intends to formally announce its next batch of Liquid Devils in the coming weeks.
