Razer has announced the BlackWidow V4 Pro, a full-blown battlestation keyboard that counts dedicated macro keys, ultra-immersive underglow lighting, endless customization options, and a Razer Command Dial as some of its chief features. According to a press release from Razer, the latter can be programmed with up to 100 Custom Modes, allowing users to map both clockwise and counter-clockwise movements to their preferred actions, including app shortcuts. The BlackWidow V4 Pro keyboard costs $229.99 USD / 269.99€ MSRP and is available beginning today at Razer.com, Razer Stores, and authorized retailers.
BlackWidow V4 Pro Gaming Keyboard Features
- Razer Mechanical Switches (Linear/Clicky)
- Razer Chroma RGB
- Razer Synapse enabled
- 5052 Aluminum Alloy Top Case
- Doubleshot ABS Keycaps
- Razer Command Dial
- 5 dedicated macros keys
- 3 dedicated macro side keys
- Dedicated media roller with 4 dedicated media buttons
- USB 2.0 Passthrough
- Detachable Type C Cables
- Case foam & PCB foam included
- Lubricated stabilizers
- Magnetic plush leatherette wrist rest
- 2-side underglow on main chassis with 3-side underglow on wrist-rest
- Hybrid on-board storage for up to 5 profiles
- Up to 8,000 Hz polling rate
“The BlackWidow line has been loved by gamers ever since it was first launched in 2010,” said Barrie Ooi, Head of Razer’s PC Gaming Division. “The BlackWidow V4 Pro features an easily customizable Razer Command Dial and dedicated macro keys, providing users with even more control. The keyboard also features 3-side keyboard underglow and per-key lighting that works seamlessly with the Razer Chroma RGB lighting ecosystem to offer a truly immersive gaming experience.”
From a Razer press release:
Customization and Control
The Command Dial is preset with 8 default modes, from window zooming to browser tab switching. Furthermore, users can program the dial with up to 100 Custom Modes, allowing them to map both clockwise and counter-clockwise action of the dial to their preferred action. For day-to-day use, users can program multiple application shortcuts, such as Photoshop brush size adjustment, timeline jogging, and more. Each mode can be toggled with a simple click of the Command Dial and easily identified by the color-coded backlight of the dial.
There are 5 macro keys placed to the left of the main keyboard layout for easy access. These can be used to activate complex actions, all programmable either through Razer Synapse or with on-the-fly macro recording. Additionally, the keyboard boasts 3 macro keys along its edge, providing a total of 8 conveniently positioned macro keys on the keyboard.
Immersive Razer Chroma RGB
The BlackWidow V4 Pro is designed for all-out immersion through Razer Chroma RGB. The keyboard comes with per-key lighting, shining brightly through the transparent switch housing for a brighter, more vivid RGB effect. This is amplified by equally bright 38-zone underglow lighting, which is extended onto the magnetically attached plush leatherette wrist rest, giving even more RGB immersion to the user.
Through Razer Synapse, users can not only synchronize all their Razer Chroma RGB enabled devices together, but also with other 3rd party Chroma Connect products. For gamers, there are over 200 Chroma-integrated games, where the RGB lighting reacts according to the actions or situations that are happening in-game.
Packed with Extra Features
The keyboard features the latest generation of Razer’s mechanical switches with the option of Green Clicky switches for tactile feedback, or Yellow Linear switches for a smooth and silent action. Both variants of the switches have undergone further testing and are now rated for up to 100-million keystrokes.
Some other notable features include: USB 2.0 passthrough, detachable Type C connections, a durable 5052 aluminum alloy top case, dual-angle kickstands, and up to 8000 Hz polling rate. Lastly, the keyboard includes 2 layers of sound dampening foam internally and factory-lubricated stabilizers for improved typing acoustics.
Boasting an abundance of macro keys, the new Razer Command Dial, and a full coverage RGB lighting, the Razer BlackWidow V4 Pro is the ultimate immersive battlestation keyboard.
