Amazon Basics is a private label brand owned by Amazon that offers a wide range of affordable products under various categories that include electronics, home and kitchen, office supplies, pet supplies, and more. According to a new listing that can be found on Amazon.com, Amazon Basics is now beginning to target PC enthusiasts, having designed its first CPU cooler, one that features four heat pipes and a cooling fan with RGB LEDs. Seemingly a rebranded Cooler Master Hyper H410R RGB, It is currently in stock for $26.99.
Amazon Basics Computer Cooling Fan Features
- CPU cooling fan; compact size ideal for small form factor systems
- Quiet fan with cooling pulse width modulation (PWM); max. noise level: 29.38 dBA
- Fan speed adjustable for maximum airflow; fan speed: 600-2000 RPM (PWM) ± 10% ; fan airflow: 34.73 CFM
- 4 heat pipes with Direct Contact technology for reliable heat dissipation
- Stacked aluminum fin design for optimal airflow towards the heat pipes
- RGB LED controller for customizable colors and effects at the touch of a button
- Snap-on bracket for quick, easy installation and removal
- Product dimensions: 4.02 x 3.28 x 5.35 inches (LxWxH); 0.9 lbs
- CPU Socket compatibility: LGA 1700, LGA 1200, LGA 1151, LGA 1150, LGA 1155, LGA 1156, AM4, AM5
