Cooler Master Launches Mobius 120 OC Case Fan
Image: Cooler Master
Cooler Master has launched the Mobius 120 OC, a new top-of-the-line case fan that is packed with innovative features. According to the high-performance PC component and peripherals brand, the Mobius 120 OC not only delivers near silent operation, but also offers complete control over its operation. Cooler Master didn’t share a price for the Mobius 120 OC in its press release, but it’s been listed at retailers that include Amazon for $39.99.
Cooler Master Mobius 120 OC Features
  • Up to 3200rpm mode via a toggle
  • Lifetime warranty
  • Metal motor hub for increased durability and lifetime performance
  • Double ball bearing design to minimize friction and enable exceptional lifespan
  • The new Ring Blade design with interconnecting fan blades for increased structural rigidity and directed airflow
  • Patented corner-mount design with rubber feet to reduce vibrations, provide stabilization, and offer quieter performance.
  • Variable speed control via a cable toggle for more wider control and usability
Cooler Master Mobius 120 OC Product Sheet
From a Cooler Master press release:
The Mobius 120 OC carries on the award-winning features that made this case fan series stand out: A ring blade design using interconnecting fan blades for improved structural rigidity and directed airflow. To further reduce vibration, the fan comes with a patented corner-mount design with rubber feet to keep it stable and quiet, while reaching an RPM speed of 3200 ±10%. And, to increase the fan’s lifespan and lower noise levels, Cooler Master uses a double ball bearing design. This combination demonstrates the company’s commitment to refining every detail for a superior final product.
The list of features doesn’t stop there. Cooler Master engineers also included a speed toggle switch that allows the user to adjust the fan speed to match any computing need she or he tackles without relying on software of BIOS control. Finally, the center motor hub is made of metal to enhance stability and increase the fan’s lifespan. To top it all, it is backed with a lifetime warranty which is a testimony to Cooler Master’s faith in this flagship case fan.
Mobius Series
The Mobius 120 OC is a new addition to Cooler Master’s Mobius case fan series. Following the introduction of the Mobius 120 and Mobius 120P ARGB in September 2022, the manufacturer released the Mobius 120P ARGB White and Mobius 140P ARGB during CES 2023 in Las Vegas. The Mobius 120 OC is the flagship model in this line-up, with a Double Ball Bearing and RPM speed that goes up to 3200 ±10%.
