Phanteks has announced that the Eclipse G300A will be available this month for $69.99 | €59.90 | £54.90 (single fan) and $79.99 | €69.90 | £64.90 (triple fans). Featuring a satin black finish, the Eclipse G300A is a new series of compact ATX cases that is said to offer exceptional value, with high-airflow performance being one of its touted features. And despite its relatively smaller footprint, Phanteks says the Eclipse G300A should have no problem fitting some of today’s larger GPUs, including ASUS’ ROG Strix GeForce RTX 4090.
Phanteks Eclipse G300A Compact ATX Case Features
- High airflow mesh with triple 120mm front fan support.
- Rear D-RGB fan and D-RGB MB adapter included.
- 360mm GPU support with 30mm front fans combined.
- 360 radiator support in the front, 240 radiator support in the top.
- Easily accessible front I/O featuring a USB 3.0 Type A and Type C, Microphone/Headphone Combo, Power button, and Reset button.
- Storage support with 3x dedicated SSD locations and a 3.5” HDD location.
From a Phanteks press release:
The G300A chassis features a sleek and minimalist design that combines high-quality materials making it the perfect fit for any environment. The chassis can accommodate ATX motherboards and large GPUs, like the ASUS RTX4090 STRIX, that can fit perfectly even with front fans installed. Effortlessly cool high-end CPUs with support for front 360 or top 240 radiator while providing ample space for a powerful system build.
The G300A chassis features a unique I/O panel with two USB 3.0 ports (1x Type A & 1x type C) and a microphone / headphone jack, allowing for easy access to all your peripherals. The chassis also includes a tempered glass side panel, which allows you to showcase your build and adds a touch of elegance to your setup.
The G300A chassis is optimized for airflow, with a mesh front panel that provides maximum ventilation and a dust filter that keeps your system clean and free of debris. The chassis also includes cable management features, allowing you to keep your cables organized and out of the way for a clean and professional look.
Gamers and professionals alike will appreciate the exceptional value and high performance of the G300A, which will be available in both single and triple fan configurations.
