Minisforum has announced that it will be selling two new mini PCs called the UM790Pro and UM780Pro with AMD Ryzen 7040HS Series processors and Radeon 780M graphics. The UM790Pro features the Ryzen 9 7940HS, an 8C/16T processor with maximum boost clock of up to 5.2 GHz, while the UM780Pro features the Ryzen 7 7840HS, an 8C/16T processor with maximum boost clock of up to 5.1 GHz. Both of these new mini PCs from Minisforum feature a brand-new cooling system dubbed “Cold Wave 2.0,” but pricing and availability details appear to be reserved for a later date.
From a Minisforum press release:
MINISFORUM has introduced its latest products, the UM790Pro and UM780Pro. These new mini-PCs are based on the AMD Ryzen 7040HS series and an all-new Cold Wave 2.0 cooling system, showcasing MINISFORUM’s dedication to innovation and research in the field of mini-PCs.
The UM790Pro packs the AMD Ryzen 9 7940HS processor, while the UM780Pro features the Ryzen 7 7840HS processor, running at maximum speeds of 5.2GHz and 5.1GHz respectively. The powerful 12-core integrated AMD Radeon 780M graphics can deliver performance comparable to dedicated graphics cards at a fraction of the cost.
Unlike previous products, UM790Pro/UM780Pro uses a brand new cooling system for better heat dissipation. Except the liquid-cooled processors, active memory and hard disk drive coolers are also provided.
Besides, the UM790Pro/UM780Pro features Killer Series wireless network card that optimizes network configuration, reducing latency and ensuring smooth gameplay. According to the gaming tests, the performance is around 109 fps in Player Unknown’s Battlegrounds, 180 fps in League of Legends and a stable 60 fps in Honkai: Star Rail.
As for appearance, connectivity, and expandability, both computers have a metal chassis and share the same set of ports, including four USB-A ports, two HDMI ports, an RJ45 Ethernet port, and two full-speed PD-powered USB4 ports (supporting RAID0 and RAID1 arrays) for flexible and scalable high-resolution and refresh-rate display options. The UM790Pro/UM780Pro supports dual-channel DDR5 5600MHz high-frequency memory, and dual PCIe 4.0 x4 SSD.
In addition to the UM790Pro and UM780Pro announced today, Minisforum will be releasing the next upcoming Mercury Series models soon- a new generation of 1/4-liter ultra-mini PC with AMD Ryzen 7 7840U variants options
