Samsung Begins Mass Production of 16 Gb DDR5 DRAM on 12-Nanometer Process Technology
Image: Samsung
Samsung Electronics has announced that its 16-gigabit (Gb) DDR5 DRAM, which utilizes the industry’s most advanced 12 nanometer (nm)-class process technology, has started mass production. The new 12-nanometer-class DDR5 DRAM offers a maximum speed of 7.2 Gbps, which Samsung has noted as being fast enough to process two 30 GB UHD movies in “about a second,” as well as outstanding power efficiency, with reduced power consumption by up to 23% while enhancing wafer productivity by up to 20%. Samsung believes its newest DRAM will optimize next-generation computing, including artificial intelligence applications, with greater power efficiency and productivity.
“Using differentiated process technology, Samsung’s industry-leading 12nm-class DDR5 DRAM delivers outstanding performance and power efficiency,” said Jooyoung Lee, Executive Vice President of DRAM Product & Technology at Samsung Electronics. “Our latest DRAM reflects our continued commitment to leading the DRAM market, not only with high-performance and high-capacity products that meet computing market demand for large-scale processing but also by commercializing next-generation solutions that support greater productivity.”
From a Samsung Newsroom press release:
Compared to the previous generation, Samsung’s new 12nm-class DDR5 DRAM reduces power consumption by up to 23% while enhancing wafer productivity by up to 20%. Its outstanding power efficiency makes it the ideal solution for global IT companies that want to reduce the energy consumption and carbon footprint of their servers and data centers.
Samsung’s development of 12nm-class process technology was made possible thanks to the use of a new high-κ material that helps increase cell capacitance. High capacitance results in a significant electric potential difference in the data signals, which makes it easier to accurately distinguish them. The company’s efforts to lower operating voltage and reduce noise have also helped deliver the optimal solution that customers need.
Boasting a maximum speed of 7.2 gigabits per second (Gbps) — translating into speeds that can process two 30GB UHD movies in about a second — Samsung’s 12nm-class DDR5 DRAM lineup will support a growing list of applications including data centers, artificial intelligence, and next-generation computing.
Samsung completed its 16-gigabit DDR5 DRAM evaluation for compatibility with AMD last December, and continues to collaborate with global IT companies to drive innovation in the next-generation DRAM market.
