Corsair Announces DOMINATOR TITANIUM DDR5 Memory with Replaceable RGB Bars and DHX Technology (Up to 8,000 MT/s, 192 GB)
Image: Corsair
Corsair has announced that DOMINATOR TITANIUM DDR5 kits will be available beginning July 2023 from the Corsair webstore and Corsair’s worldwide network of authorized retailers and distributors. “Luxury. Performance. Own both,” reads a promotion for the new memory modules, which Corsair says are built using some of the fastest DDR5 ICs available, complemented with patented CORSAIR DHX cooling technology—a custom-designed PCB that cools the front and rear of the DRAM chips, as well as the PCB—for improved overclocking potential. Corsair is celebrating the launch of DOMINATOR TITANIUM DDR5 with a limited (500) run of individually numbered, First-Edition kits that feature tight timings and higher frequencies. Users will also find a unique feature in the form of replaceable top bars for those who want to switch between an RGB or fin aesthetic.
From a Corsair press release:
Sporting an elegant, fresh new design and built using premium materials and components, DOMINATOR TITANIUM DDR5 memory will be available for both Intel and AMD platforms, supporting Intel XMP 3.0 when paired with 12th and 13th-Gen Core processors or AMD EXPO for Ryzen 7000 CPUs. These technologies enable easy overclocking in just a couple of clicks on compatible platforms.
An exciting new feature with DOMINATOR TITANIUM is support for fully replaceable top bars, allowing owners to customize their memory for specific aesthetics. Anyone looking to go for a minimalist or classic style can do so with the separately available Fin Accessory Kits that replace the RGB top bars with bars that utilize fins for an elegant look that harkens back to the original DOMINATOR memory.
Boasting 11 vibrant individually addressable RGB LED along its removable top-bar, DOMINATOR TITANIUM offers seamless lighting arrays to illuminate your system. More advanced system-wide effects are possible when combined with the powerful CORSAIR iCUE Murals, for synchronized lighting that matches your music, games, or movies.
DOMINATOR TITANIUM will launch with phenomenal speeds up to 8,000MT/s and capacities up to 192GB (4x 48GB) with CAS latencies as low as 30 on some SKUs. Showing its ability to go beyond even this high frequency performance, CORSAIR will be demoing DOMINATOR TITANIUM running at speeds of 8,266MT/s at its Grand Hyatt booth at COMPUTEX 2023.
CORSAIR will celebrate the launch of the latest version of DOMINATOR Memory with a limited run of First-Edition kits, boasting tight timings and higher frequencies. Limited to just 500 kits and individually numbered, enthusiasts will need to act fast to secure a unique piece of CORSAIR history.
As with all CORSAIR DDR5 memory, DOMINATOR TITANIUM modules are built using hand-sorted, tightly screened memory chips to ensure consistently high frequencies, atop performance PCBs for excellent signal quality and stability. Cooling these chips is a stylish solid aluminum heatspreader that efficiently conducts heat away from your memory, while complementing your system’s modern aesthetic. A limited lifetime warranty grants you peace of mind that your new memory will last throughout your PC’s lifespan and future upgrades.
Image: Corsair
