Fractal Design Introduces Terra SFF Gaming Cases with Solid Walnut Panel
Image: Fractal Design
Fractal Design has launched the Terra, a new series of small form factor PC gaming cases that can fit GPUs up to 322 mm in length and is now available to purchase in three colors, including Jade, for $179.99. Featuring a design inspired by the homes of modern gamers, Terra boasts a selection of fashionable elements, including anodized aluminum panels, precision CNC-milled details, and an FSC-certified solid walnut panel at the front. Another highlight of the Terra is its stepless slidable central wall, a feature that goes toward build flexibility.
Fractal Terra Small Form Factor Gaming Case Highlights
  • Install your choice of powerful GPU up to 322 mm in length, in a space-saving 10.4 L case
  • Add natural materials to your setup with a front-facing panel cut from FSC-certified solid walnut
  • Enjoy a sleek anodized aluminum exterior including an 8 mm-thick aluminum front
From a Fractal Design post:
Inspired by the homes of modern gamers, Terra has been crafted to lift the desk environment and harmonize powerful gaming technology into their living space. To achieve this, it incorporates boutique design features such as panels cut from anodized aluminum, including an 8 mm-thick aluminum front and a panel made from FSC-certified solid walnut.
From building through to daily use, Terra was designed with user interaction in mind. Whether someone rotates open the aluminum side panels, slides open the top with the integrated tab or presses the laser-engraved aluminum power button — every interaction with Terra is designed to feel smooth and enjoyable.
Inside, Terra hides smart features such as a stepless slidable central wall, allowing users to adapt the space ratio between compartments by up to 30 mm. This gives builders the freedom to design their small form factor gaming PC around their component choices, including the option to incorporate a in a space-saving 10.4 L case.
