ASUS Announces Prime 750W Gold and 850W Gold ATX 3.0 Power Supplies
Image: ASUS
ASUS has announced the Prime 750W Gold and Prime 850W Gold, new ATX 3.0 power supplies aimed at NVIDIA GeForce RTX 40 Series owners that feature fully modular cables, a single 12VHPWR connector, and an eight-year warranty. Featuring a white, outer space-inspired design, ASUS says they’re a great match for its Prime motherboards, as well as Dual GeForce RTX 4070 OC and Dual GeForce RTX 4070 White OC graphics cards.
ASUS Prime 750W/850W Gold Features
  • Dual ball fan bearings that can last up to twice as long as sleeve bearing designs.
  • An 80 Plus Gold Certification is the result of Japanese capacitors and other premium components.
  • ATX 3.0 compatible: ASUS Prime Gold is compliant with ATX 3.0 guidelines and bundled with a 16-pin PCIe cable that is compatible with PCIe Gen 5.0 graphics cards.
  • 8-year warranty included.
ASUS Prime Gold Series power supplies are loaded with all of the features that PC builders have come to expect from a high-quality PSU. Both models are fully modular, allowing users to cut down on build clutter by only using the cables they need. As ATX 3.0-compatible power supplies, the ASUS Prime Gold Series units are also fully compatible with NVIDIA GeForce RTX 40 series graphics cards, thanks to their native 16-pin 12VHPWR cable.
Meanwhile, dual-ball bearing fans ensure that all the power delivery components stay cool, with longer-lasting durability thanks to lower friction. And ASUS Prime Gold Series PSUs feature a stylish, outer space-inspired design. With one side black and the other white, these power supplies are sure to fit right into a wide variety of builds and cases. This space-age design is a great match for not only existing Prime motherboards and cases but also the Dual graphics card series, such as the ASUS Dual GeForce RTX 4070 OC and Dual GeForce RTX 4070 White OC.
