addlink AddGame Spider X5 RGB DDR5 32GB (2x16GB) 6400MHz Memory Review
Gaming Benchmarks
For our gaming benchmarks, we set the graphics settings to the highest defaults in each game (without using Ray Tracing, FSR, DLSS, etc.) and tested at both 1080p and 4k resolutions using the built-in benchmarks.
1080p Gaming
Shadow of the Tomb Raider
AddGame Spider X5 RGB 32GB (2x16) 6400MHz Memory Shadow of the Tomb Raider 1080p results
At 1080p in Shadow of the Tomb Raider, the AddGame Spider X5 RGB 32GB (2×16) 6400MHz Memory clocked in at 240FPS as well as overclocked in at 240FPS. This is 1FPS better than the 6000MHz competition.
Horizon Zero Dawn
AddGame Spider X5 RGB 32GB (2x16) 6400MHz Memory Horizon Zero Dawn 1080p results
In Horizon Zero Dawn at 1080p, the AddGame Spider X5 RGB 32GB (2×16) 6400MHz Memory clocked and overclocked in at 199FPS, a single FPS above the 6000MHz competition.
Watch Dogs: Legion
AddGame Spider X5 RGB 32GB (2x16) 6400MHz Memory Watch Dogs Legion 1080p results
In Watch Dogs: Legion at 1080p, we found a bit more variation with the AddGame Spider X5 RGB 32GB (2×16) 6400MHz Memory landing at 135 FPS, a single FPS above the 6000MHz competition. However, overclocking the AddGame Spider X5 RGB 32GB (2×16) 6400MHz Memory boost us by a whole two FPS to 137.
Cyberpunk 2077
AddGame Spider X5 RGB 32GB (2x16) 6400MHz Memory Cyberpunk 2077 1080p results
In Cyberpunk 2077 at 1080p, the AddGame Spider X5 RGB 32GB (2×16) 6400MHz Memory took the top spot at 149.4 FPS which was 1.9% above and beyond the 6000MHz competition. However, overclocking lost a little bit of that edge indicating timings may be more important in this game.
4k Gaming
AddGame Spider X5 RGB 32GB (2x16) 6400MHz Memory Shadow of the tomb raider 4k results
In Shadow of the Tomb Raider at 4k we found that field was tied at 98 FPS.
Horizon Zero Dawn
AddGame Spider X5 RGB 32GB (2x16) 6400MHz Memory Horizon Zero Dawn 4k results
In Horizon Zero Dawn at 4k, both the AddGame Spider X5 RGB 32GB (2×16) 6400MHz Memory and its 6000MHz competition provided 96FPS. We lost a single FPS with the overclocking efforts.
Watch Dogs: Legion
AddGame Spider X5 RGB 32GB (2x16) 6400MHz Memory Watch Dogs Legion 4k results
In Watch Dogs: Legion at 4k the AddGame Spider X5 RGB 32GB (2×16) 6400MHz Memory presented 65FPS in both its XMP and overclocked flavors. The 6000MHz competition somehow edged them at 66FPS.
Cyberpunk 2077
AddGame Spider X5 RGB 32GB (2x16) 6400MHz Memory Cyberpunk 2077 4k Results
Finally, in Cyberpunk 2077 at 4k the AddGame Spider X5 RGB 32GB (2×16) 6400MHz Memory tied with its 6000MHz competition at 49.4FPS. Overclocking the AddGame Spider X5 RGB 32GB (2×16) 6400MHz Memory took the crown at a whopping 0.1FPS faster.
Performance
Aesthetics
Price Value
The AddGame Spider X5 RGB 32GB (2x16) 6400MHz Memory was tested using its XMP profile on our Intel 13900K based platform and we found it to be a solid performer with room in the tank for a bit of overclocking. It has RGB functionality to light up your build and was priced fairly to its competition at the time of publication which makes it a good buy for your next rig.
