ASUS Launches TUF Gaming LC II 360 ARGB AIO Liquid Cooler with 360 mm Radiator
Image: ASUS
ASUS has expanded its lineup of coolers with the TUF Gaming LC II 360 ARGB, a new AIO liquid cooler that features an illuminated coldplate, reinforced sleeved tubing, a high-capacity radiator, three 120 mm ARGB fans, and other premium features. According to a writeup that can be found on ASUS’ Edge Up blog, this is the first TUF GAMING AIO liquid cooler to feature a 360 mm radiator, and it also comes with brighter ARGB lighting, making for an even more eye-catching display. Compatibility includes AMD AM5 and Intel LGA 1700 platforms.
ASUS TUF Gaming LC II 360 ARGB AIO Liquid Cooler Features
  • TUF Gaming radiator fans upgraded with brighter ARGB lighting, and grooved fins for improved airflow and lower noise
  • Styled to complement TUF Gaming motherboards, at the center stage of your build
  • Reinforced, sleeved 400mm tubing for increased durability and chassis compatibility
  • Support for Intel LGA 1700, 1200, 115x, and AMD AM5 and AM4 sockets
Liquid cooling radiators can play a large role in setting the aesthetic tone of your build, especially if they’re mounted vertically in a dual-chamber chassis like the TUF Gaming GT502. The TUF Gaming LC II 360 ARGB AIO liquid cooler embraces its role on the main stage with a new ID design crafted to perfectly complement your TUF gaming motherboard, graphics card, or chassis.
We’ve upgraded the radiator fans with brighter Gen 2 ARGB lighting, too. These eye-catching RGB LEDs will put a spotlight on your carefully constructed build. ASUS Aura Sync makes it easy to synchronize their color with the rest of your components and peripherals for a cohesive look.
As the first TUF Gaming AIO liquid cooler with a massive 360mm radiator, the TUF Gaming LC II 360 ARGB already takes the series to new levels of thermal performance. But there’s more. To improve airflow and reduce noise, the radiator features grooved fins that direct cooling air with precision.
A trio of 120mm ARGB fans provide an excellent balance of airflow, static pressure, and noise production. These spinners can move a substantial quantity of cooling air through the radiator, all while keeping noise levels below 29dB for effortless cooling.
Wide compatibility with several generations of motherboard sockets makes the TUF Gaming LC II 360 ARGB AIO liquid cooler an easy fit for just about any PC build. Devotees of AMD CPUs will find that this unit fits socket AM4 and AM5 motherboards, allowing you to build either a next-gen Ryzen 7000 Series PC or a budget-friendly AM4 machine. On the Intel side, this AIO liquid cooler supports LGA 1700, 1200, and 115X sockets, giving you broad support for everything from Intel’s latest 13th Gen Core chips to your favorite CPU from years past.
Chassis compatibility matters, too. Today’s larger PC cases offer versatile options for mounting a 360mm liquid cooling radiator. To ensure that you can take advantage of these options, we’ve increased the length of the sleeved tubing up to 400mm.
