EK Launches NVIDIA RTX 6000 ADA Professional GPUs for EK Fluid Works Systems
Image: EK
EK has announced that its EK Fluid Works Systems can now be configured with the RTX 6000 ADA, the professional GPU from NVIDIA that features over 18,000 CUDA cores and 48 GB of GDDR6 ECC RAM. The new graphics option, which can be added to the S300, S5000, X5000, X7000, W7000-RM, and X7000-RM systems, is complemented by the EK-Pro GPU WB RTX 6000 ADA, a water block from EK that offers 300 watts of thermal dissipation. Up to seven NVIDIA RTX 6000 ADA GPUs are supported by the X7000, W7000-RM and X7000-RM.
EK-Pro GPU WB RTX 6000 ADA Features
  • Durable and high purity materials
  • Open Split-Flow cooling engine
  • CNC-machined microchannels with minimal hydraulic flow resistance
  • EPDM rubber seals
EKFW Systems with NVIDIA RTX 6000 ADA GPUs
The water block’s excellent thermal performance slashes the GPU core and VRAM operating temperature under an extended, high-intensity load. Their lab has observed a 25°C drop in component temperature compared to air cooling at 25°C ambient temperature. This, along with the durable construction and leak-free guarantee, translates into a long service life with 24/7 maximum output of the GPU.
Supporting the new GPUs is the EK Fluid Works liquid cooling ecosystem, consisting of only the finest EK components. Multiple radiators, manifolds, and high-quality EPDM tubing coupled with QDCs ensure the optimal balance of performance, low noise output and easy serviceability.
Image: EK
