Ubisoft has shared the PC specifications and features for Assassin’s Creed Mirage ahead of its release on October 5, 2023 via the Epic Games Store and Ubisoft Store. At minimum, players will need an Intel Core i7-4790K (Intel Core i5-8400 for Intel Arc with ReBAR) or AMD Ryzen 5 1600 processor and Intel Arc A380, NVIDIA GeForce GTX 1060, or AMD Radeon RX 570 GPU to run the game, as well as 8 GB of RAM and 40 GB of free SSD storage. An uncapped frame rate, support for multi-monitor and widescreen setups, and XeSS Super Sampling, Intel’s AI-assisted upscaling solution, are some of the features that Assassin’s Creed Mirage players will find in the game, which marks the thirteenth major installment in Ubisoft’s stealth action-adventure series.
Assassin’s Creed Mirage PC Specifications (All Require DirectX 12)
1080p, LOW PRESET, 30 FPS
- CPU: Intel Core i7-4790K (Intel Core i5-8400 for Intel Arc with ReBAR)/AMD Ryzen 5 1600
- GPU: Intel Arc A380 6GB/NVIDIA GeForce GTX 1060 6GB/AMD Radeon RX 570 4GB
- RAM: 8GB (dual-channel mode)
- OS: Windows 10/11
- SSD Storage: 40 GB
1080p, HIGH PRESET, 60 FPS
- CPU: Intel Core i7-8700K/AMD Ryzen 5 3600
- GPU: Intel Arc A750 8GB/NVIDIA GeForce GTX 1660 Ti 6GB/AMD Radeon RX 5600 XT 6GB
- RAM: 16GB (dual-channel mode)
- OS: Windows 10/11
1440p (2K), HIGH PRESET, 60 FPS
- CPU: Intel Core i7-9700K/AMD Ryzen 7 3700X
- GPU: Intel Arc A770 8GB/ NVIDIA GeForce RTX 2070 8GB/AMD Radeon RX 5700 XT 8GB
- OS: Windows 10/11
2160p (4K), ULTRA PRESET, 60 FPS
- CPU: Intel Core i5-11600K/AMD Ryzen 5 5600X
- GPU: NVIDIA GeForce 3080 10GB/AMD Radeon RX 6900 XT 16GB
- OS: Windows 10/11
…you’ll be able to immerse yourself in his world with an uncapped frame rate, even in 4K; simultaneously use a keyboard, mouse, and controller (or other inputs); and get a dazzling panoramic view with HDR as well as multi-monitor and widescreen support. You’ll also be able to leverage features like Intel’s AI-assisted XeSS Super Sampling, which upscales resolution while enabling hardware to pump out more frames per second; optimization for Intel Arc GPUs and 13th-generation CPUs; synchronize ambient lighting with the game’s action using MSI’s Mystic Light products; and even experience upper-body haptic feedback with the OWO Haptic Gaming System vest (which is also supported on consoles).
