Phanteks has announced that its new lineup of D30-140 fans will be available this month as part of a single pack or triple pack, starting at $29.99. Coming in black or white color options with regular or reversed blades, these are new 140-mm aerodynamic fans from the company that feature specially designed bridge connectors and screw cover plates, allowing them to be easily linked together without cable clutter. Users will also find a significant amount of D-RGB lighting.
Phanteks D30-140 Fan Pricing
- D30-140 Regular Fan Single Pack – Black | White: $29.99 | € 29.90 | £ 29.90
- D30-140 Reverse Fan Single Pack – Black | White: $29.99 | € 29.90 | £ 29.90
- D30-140 Regular Fan Triple Pack – Black | White: $84.99 | € 84.90 | £ 84.90
- D30-140 Reverse Fan Triple Pack – Black | White: $84.99 | € 84.90 | £ 84.90
The D30 fans introduce a mesmerizing integration of D-RGB lighting that spans seamlessly across the frame and blades of the fan from all sides. A hallmark of the D30 fan is its unique capability for easy and clean fan linking. Phanteks has designed bridge connectors and screw cover plates, enabling multiple D30 fans to be seamlessly interconnected. This innovative solution reduces cable clutter and transforms multiple fans into a unified, visually striking unit, resulting in an immaculately clean build.
The D30-140 fans offer a choice of regular and reversed airflow fans, empowering users to customize cooling configurations. Enhanced by a robust 30mm frame and aerodynamic fan blades inspired by Phanteks’ renowned T30 design, these fans excel in challenging scenarios like radiators and mesh filters, delivering superior air pressure for optimal temperatures under demanding cooling needs.
Together with the upcoming Glacier One 420D30 and NV9, the D30-140 fan offers an unparalleled blend of functionality and style to pc builders. Available with regular and reverse airflow in both black and white.
