Sycom Brings Noctua Fans to GeForce RTX 4070 and RTX 4060 Ti GPUs
Image: Sycom
Sycom has introduced the Silent Master Graphics GeForce RTX 4070 and GeForce RTX 4060 Ti, two new custom graphics cards from the Japanese company that feature cooling fans from Noctua. According to benchmarks that Sycom shared, both of these GPUs only measure 31.4 dB when idle and up to 39.4 dB at high load, making them ideal for silence-oriented builds that include Sycom’s own Silent Master series of custom-build PCs with Fractal cases. A GeForce RTX 4080 with Noctua fans is also available in the form of ASUS’ GeForce RTX 4080 16GB GDDR6X Noctua OC Edition.
Silent Master Graphics measures less than 40dB even under high load. When placed in a PC case, the sound of the cooling fan has reached a level that is almost unnoticeable.
Silent Master Graphics is not only quiet but also has high cooling capacity. In particular, the Silent Master Graphics RTX4070 is equipped with two large-diameter 12cm fans, so it stays below 60 degrees even under high load.
Image: Sycom
Image: Sycom
