TEAMGROUP T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz Memory Review
TEAMGROUP mainly produces its own brand of memory modules, memory cards, USB flash drives, solid-state drives, peripheral series, and mobile accessories. Under TEAMGROUP’s banner of Memory products, it has three distinct lines, including the T-FORCE GamingT-CREATE Creator, and simply TEAMGROUP.
Today we’re taking a look at TEAMGROUP’S T-FORCE DELTA RGB DDR5 32GB (2X16GB) 7200MHz Memory kit (FF3D532G7200HC34ADC01) to see how it performs on our Rocket Lake Refresh test bed to see if its speed will put your gaming rig over the top. The T-FORCE DELTA line of memory is available in speeds ranging from 5200MHz all the way up to 8000MHz with kit capacities ranging from 8GB up to 96GB. The 7200MHz variety that we’re looking at today has timings of 34-42-42-84 at 1.4V using an XMP profile. At the time of publication, we’re seeing this kit pricing out around $120-130 in etail – check our pricing widget for current pricing.
The T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz Memory comes in a black box adorned with images of the DELTA RGB memory sticks, a label indicating the speed and capacity of the memory, an official-looking lifetime warranty stamp and a hat tip towards being Intel XMP Certified. Flipping over to the back, we’ve got the customary mice type in six languages about its features.
Inside the packaging, we found two 16GB modules labeled with the part number FF3D516G7200HC34ABK. The modules are clad in a black heat spreader which is topped by a mountain ridge-like white RGB bar that adds “T-FORCE” along the right side of the top.
The kits sport Hynix memory modules that have base timings of 46-46-46-90 using 1.1V at 5600MHz. Their tested (and marketed) frequency is PC5-57600 (7200MHz) at timings of 34-42-42-84 at 1.4V. They are equipped with a thermal sensor, on-die ECC, and support for your favorite motherboard manufacturer’s RGB bling controller.
From a sizing perspective, the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz Memory measures in at 1.82” in height, which is not the smallest that we’ve looked at but not the largest either. As usual, if you’re doing the large tower block cooler thing, keep an eye on clearances on your motherboard.
Installation and Configuration
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory installed in our test rig
We installed the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz Memory into our ASRock Phantom Gaming Z790 NOVA WIFI Motherboard that is paired with an Intel 14900K processor. The RGB entered a default pattern that paired with the other RGB bling on our test rig.
By default, the modules load up the base timings described above which is PC5-38400 (4800MHz) at 46-46-46-90 however throwing the XMP switch bumped it up to PC5-57600 (7200MHz) at timings of 34-42-42-84. We were able to boot into Windows 11 and start benchmarking without an issue.
Test Setup
We will be utilizing the ASRock Phantom Gaming NOVA WIFI motherboard and the other based on an Intel i9 14900K CPU. We will operate the Intel using the XMP profile and compare it to the AddGame Spider X5 RGB DDR5 6400MHz memory which is the current performance king for its speed based on what we have tested.
Overclocking
We started escalating the memory clock until it did not post at 7800MHz. Dropping down to 7600MHz, we got into Windows and then were escorted back to the POST screen by a BSOD. Loading up at 7400MHz with the XMP timings was the lucky move, so we rolled forward with that as our overclocking testing speed.
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory CPUZ overclocked memory tab
Synthetic Benchmarks
PCMark 10
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory PCMark 10 testing results
Starting the benchmarking ceremonies with PCMark 10, we found the T-FORCE DELTA 7200MHz memory running up a score of 9,713 PCMarks. The Addgame Spider X5 6400MHz memory outran it with a score of 9,791. However, overclocking the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory put it back in the lead with a 5-figure score of 10,056.
Geekbench 5 (Multicore)
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory Geekbench 6 multicore testing results
Moving on to Geekbench 6’s multicore test, the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory chalked up a score of 22,456 which was about 500 over the Addgame Spider X5 6400MHz memory at 21,965. Overclocking the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory added nearly 100 to its score total to reach 22,552.
Geekbench 5 (Singlecore)
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory Geekbench 6 single core testing results
Dropping to a single core test with Geekbench 6 finds the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory at 3,077 points which is 23 lower than the Addgame Spider X5 6400MHz memory kit. Overclocking did not do any favors and lowered the score by 11 points.
AIDA64 Memory Read
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory AIDA64 memory read testing results
We put on AIDA64’s memory reading glasses and the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory belted out 109,063MB/s of page turning which was about 10,000MB/s faster than the Addgame X5 Spider 6400MHz memory. Overclocking boosted read speeds to 112,464MB/s.
AIDA64 Memory Write
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory AIDA64 memory write testing results
With AIDA64’s memory writing test, the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory achieved 94,154MB/s which was faster than the Addgame X5 Spider 6400MHz memory at 86,967MB/s. Overclocking added a couple extra gigs per second to reach 96,560MB/s.
AIDA64 CPU Queen
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory AIDA64 cpu queen testing results
On AIDA64’s CPU Queen test, we found the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory at the back of the pack at 162,629 which was a couple hundred below the Addgame X5 Spider 6400MHz memory. Overclocking allowed the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory to pull out a win about 40 higher than the Addgame kit. Keep in mind that the margins on this test are likely within the margin of testing error.
AIDA64 SHA3
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory AIDA64 SHA3 testing results
For the AIDA64 SHA3 test, the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory delivered a score of 9220, which was 21 lower than the Addgame X5 Spider 6400MHz memory. Overclocking boosted the score by 17. Of note, these results are all likely within the margin of error for the test.
CineBench R23 (Multi Core)
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory Cinebench R23 multicore testing results
Taking CineBench for the ride finds the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory delivering a score of 39,227 which defeats the Addgame X5 Spider 6400MHz memory’s 38,046 score. Overclocking the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory pushes performance over the 40k level to 40,086.
CineBench R23 (Single Core)
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory Cinebench R23 singlecore testing results
On the single core front, the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory takes the loss at 2,173 as the Addgame X5 Spider 6400MHz memory turned in a score of 2,218. However, overclocking fixes the competition for the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory at a score of 2,265.
VRay 5
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory Vray5 testing results
For our final synthetic test with VRay 5, we found the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory at a score of 26,885 which was about two fifty below the Addgame X5 Spider 6400MHz memroy at 27,115. Overclocking the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory puts it back on top at 27,299.
1080p Gaming Benchmarks
Cyberpunk 2077
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory 1080p cyberpunk 2077 testing results
In Cyberpunk 2077 at 1080p, we found the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory at the top of the heap at 149.5 FPS which beat the Addgame X5 Spider 6400MHz memory by 1.3 FPS. Overclocking the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory did no favors and slowed the party down to 148.7 FPS.
Watch Dogs: Legion
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory 1080p watch dogs legion testing results
In Watch Dogs Legion, the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory was clocked at 139 FPS which was 3 FPS higher than the Addgame X5 Spider 6400MHz memory. Overclocking again dropped performance by a couple of frames here.
Shadow of the Tomb Raider
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory 1080p shadow of the tomb raider testing results
In Shadow of the Tomb Raider, the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory arrived at 244FPS which caused a narrow loss to the Addgame X5 Spider 6400MHz memory’s 245FPS effort. T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory dropped 3 FPS off its overall performance.
Horizon Zero Dawn
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory 1080p horizon zero dawn testing results
In Horizon Zero Dawn, the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory delivered 202 FPS which was one higher than the Addgame X5 Spider 6400MHz memory. Overclocking saw no change in results.
4K Gaming Benchmarks
Cyberpunk 2077
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory 4K cyberpunk 2077 testing results
At 4K in Cyberpunk 2077, we found ourselves splitting single ply toilet paper into half ply toilet paper to see a difference in the results. The T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory landed at 44.8FPS, which was .3 higher than the Addgame X5 Spider 6400MHz memory. Overclocking landed it in the middle at 44.6FPS.
Watch Dogs: Legion
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory 4K watch dogs legion testing results
In Watch Dogs Legion at 4K, the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory delivered 66FPS which was one slower than the Addgame X5 Spider 6400MHz memory. Overclocking the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory tied it all up at 67FPS.
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory 4K shadow of the tomb raider testing results
In Shadow of the Tomb Raider at 4k, the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory took the loss at 97 FPS as the Addgame X5 Spider 6400MHz memory boasted a 99FPS result. Overclocking brought performance parity at 99FPS.
Horizon Zero Dawn
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory 4K horizon zero dawn testing results
In Horizon Zero Dawn at 4k, T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory tied with the Addgame Spider X5 6400MHz memory at 97FPS. Overclocking yielded the same 97FPS performance.
T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz front view on a stand
Today we took a look at TEAMGROUP’S T-FORCE DELTA RGB DDR5 32GB (2X16GB) 7200MHz Memory kit and compared its performance to a recent 6400MHz kit that we looked at on our Intel 14900K-based testing platform. We also overlocked it to see how much headroom we could find within the modules.
The T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory includes a pair of memory sticks that are loaded with XMP profiles, the fastest of which is set to 34-42-42-84 timings at 1.4V. It also sports an RGB array across the top that can be controlled by your favorite motherboard manufacturer’s RGB center.
From an overall perspective, the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory was a solid performer on our test bench and delivered a high level of stability. Other than overclocking it too far, it was simply rock solid on our test bench (which is better than another 7200MHz kit that we’ve been attempting to review).
Putting it all together, we’re seeing the T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory go for $120-130 at the time of publication which is among the lowest-priced 32GB kits of 7200MHz DDR5 that are available in etail today. It also represents about a $20 premium over 6400MHz spec’ed memory.
The T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory was rock stable for us in testing and delivered performance consistent with its speed and it should absolutely be on your shortlist for your next build.
Performance
Aesthetics
Price Value
The T-FORCE DELTA RGB DDR5 32GB (2x16GB) 7200MHz memory was tested using its XMP profile on our Intel 14900K based platform and we found it to be a solid, stable performer that lit itself up with RGB as it worked. Based on pricing at the time of the review, it represents a fantastic value for this amount of memory speed and is worthy of your dollars.
