Cooler Master Introduces Its 2000W X Mighty Platinum 80+ Power Supply Which Includes Two 90° 12V-2×6 Cables
Image: Cooler Master
PC owners looking for a great amount of power need look no further as Cooler Master introduces its X Mighty Platinum power supply. Cooler Master debuted its new X Mighty PSU line at CES 2024 where it showed off the new 2000W model and its slightly larger sibling, 2800W version. Don’t be fooled by the X Mighty Platinum’s wattage potential because the 2000W is 80+ Platinum certified meaning it can achieve an efficiency of 92% during typical workloads. It also supports the ATX 3.1 standard, PCIe 5.1, and comes with two heavy-duty right-angle 12V-2×6 cables capable of delivering up to 600W to two GPUs.
As Cooler Master introduces the X Mighty Platinum 2000W it includes many premium features in its construction to ensure maximum performance and reliability. An exclusive aluminum thermal heatsink is paired with a 2000 RPM 120mm fan and is capable of zero-rpm operation for silent running. Cooler Master has designed the X Mighty Platinum 2000W with an active bridge rectifier which replaces traditional bridge diodes with Infineon CoolMOS for further improved power efficiency and reliability. Cooler Master’s MasterCTRL software enables real-time monitoring of the PSU and is a part of the company’s MasterHub software suite which was also shown off at CES 2024.
Key Features (via press release):
  • 80 Plus Platinum Efficiency: This unit is certified to achieve more than 92% efficiency at typical loads in a 115V test.
  • Active bridge rectifier: Bridge diodes have been replaced with an active bridge rectifier to improve performance.
  • ATX 3.1 support & two durable 12V-2×6 cables: Includes ATX 3.1 support and two 90-degree 12+4pin (12V-2×6) PCIe 5.1 cables featuring lower temperatures, enhanced durability, and improved safety.
  • Digital Monitoring with MasterCTRL: Cooler Master’s MasterCTRL software allows users to monitor temperature, current load, and performance metrics.
  • Long-lasting reliability: Built with Infineon industrial-grade IC chips for high quality performance and long-lasting reliability.
Cooler Master has not revealed pricing and availability for the new PSU but has said that it will be covered by a 10-year warranty.
Specifications (via product page):
  • Model: MPS-K001-AFBP
  • ATX Version: ATX 12V Ver. 3.0
  • PFC: Active PFC
  • Input Voltage: 200-240V
  • Input Current: 12A (Max)
  • Input Frequency: 50-60Hz
  • Dimensions (L x W x H): 180 x 150 x 86 mm
  • Fan Size: 120mm
  • Fan Bearing: LDB
  • Fan Speed: 2000 RPM
  • Efficiency: ≥ 94% @ Typical Load
  • 80 PLUS Rating: 80 PLUS Platinum
  • ErP 2014 Lot 3: Yes
  • Operating Temperature: 0-50°C
  • Power Good Signal: 100 – 150 ms
  • Hold Up Time: ≥ 16ms
  • MTBF: >100,000 Hours
  • Protections: OPP, OVP, OTP, OCP, SCP, UVP, Surge and Inrush Protection
  • Regulatory cUL, TUV, CE, FCC, CCC, EAC, RCM, UKCA/BIS, KC (based on region’s request.)
  • ATX 24 Pin Connectors: 1
  • EPS 4+4 Pin Connectors:1
  • EPS 8 Pin Connector: 1
  • SATA Connectors: 12
  • Peripheral 4 Pin Connectors: 4
  • PCI-e 6+2 Pin Connectors: 4
  • 12V-2×6 Connectors: 2
  • USB 10P Connector: 1
  • Series: X Series
  • 80 Plus: Platinum
  • Modular: Fully Modular
  • Wattage: Above 750W
