GIGABYTE has expanded its range of NVIDIA GPUs with the GeForce RTX 40 EAGLE OC ICE series and GeForce RTX 3050 6G graphics cards. The former includes four models, while the latter includes two models, including a low-profile option.
GeForce RTX 40 EAGLE OC Ice Series:
- GeForce RTX 4070 Ti SUPER EAGLE OC ICE 16G
- GeForce RTX 4070 SUPER EAGLE OC ICE 12G
- GeForce RTX 4060 Ti EAGLE OC ICE 8G
- GeForce RTX 4060 EAGLE OC ICE 8G
GeForce RTX 3050 6G Series:
Press release (EAGLE OC Ice series):
The latest EAGLE OC ICE series presents a white iteration of the well-received EAGLE OC graphics card series. With exceptional performance catering to the diverse requirements of gamers, creators, and AI developers, it features an extensive integration of white materials in its design. This introduces an alternative choice for gamers who appreciate white-themed setups.
GIGABYTE has introduced four models in the GeForce RTX 40 EAGLE OC ICE series, corresponding to the GeForce RTX 4070 Ti SUPER, GeForce RTX 4070 SUPER, GeForce RTX 4060 Ti, and GeForce RTX 4060 GPUs. The EAGLE OC ICE series features a brand-new white exterior design inspired by space technology and incorporates futuristic design elements. The graphics cards come with white covers and backplates, complemented by cosmic-themed graphics, symbols, and geometric shapes, providing a unique and personalized appearance for white-themed desktop setups.
Additionally, the GeForce RTX 4070 Ti SUPER EAGLE OC ICE 16G and the GeForce RTX 4070 SUPER EAGLE OC ICE 12G come with RGB lighting, allowing users to customize different colors and modes through the GIGABYTE CONTROL CENTER software for a distinctive and vibrant lighting effect.
The GIGABYTE GeForce RTX 40 EAGLE OC ICE series graphics cards are powered by the WINDFORCE cooling system. It features unique blade fans, alternate spinning, composite copper heat pipes, 3D active fans, and screen cooling to maximize the heat dissipation. The WINDFORCE fans utilize graphene nano lubricant, which extends fan life by 2.1 times, delivering nearly the same lifespan of the double ball bearing while providing quiet operation. The onboard dual BIOS switch allows users to choose the SILENT mode for a quieter experience at ease.
GIGABYTE not only pursues innovation in computer technology but also leads the trend in exterior design, offering a series of computer components that align with fashion trends. A variety of white-themed options are provided to meet the diverse needs of consumers. The introduction of the EAGLE OC ICE series graphics card provides a more minimal and personalized choice for gamers who favor white-themed desktop setups.
Press release (GeForce RTX 3050 6G):
The GeForce RTX 3050 EAGLE OC 6G and GeForce RTX 3050 OC Low Profile 6G graphics cards are powered by Ampere- NVIDIA’s 2nd gen RTX architecture, featuring dedicated RT cores, AI Tensor cores, and fast GDDR6 graphics memory. They deliver the most realistic ray tracing graphics and advanced AI features with DLSS. In addition to providing gamers with a visually stunning and smooth 1080p gaming experience, creators can also indulge in the joy of creative expression.
The GIGABYTE GeForce RTX 3050 EAGLE OC 6G graphics card incorporates futuristic design elements, presenting distinctive and personalized features through cosmic-themed graphics, symbols, and geometric shapes. The GIGABYTE GeForce RTX 3050 EAGLE OC 6G is equipped with the GIGABYTE WINDFORCE cooling system. Featuring unique blade fans, alternate spinning, and fan stop functionalities, this cooling system efficiently lowers the working temperature of the graphics card, ensuring stable performance even under high-demand operations.
The Alternate Spinning technology reverses the rotation direction of adjacent fans, making the airflow direction between the two fans the same. This reduces turbulence and enhances air pressure, improving the cooling efficiency. The fans utilize nano-graphene lubricant, enhancing lifespan by up to 2.1 times, approaching the durability of double ball bearings while maintaining a quieter operation. Combined with excellent power design and the use of ULTRA DURABLE certified components, the graphics card can operate at lower temperatures and higher performance.
The GIGABYTE GeForce RTX 3050 OC Low Profile 6G graphics card is only 181 mm long and 69 mm high in size. It comes with a low-profile graphics card bracket in the box. This makes it easy to install in a variety of thin cases, making it a great option for small form factor builds.
The graphics card features GIGABYTE’s customized cooling system, which features a dual-fan design and a high-performance copper heat pipe that directly contacts the GPU. This helps to quickly dissipate heat to the heatsink. In addition, the use of ULTRA DURABLE certified components ensures that even such a compact graphics card can provide stable performance.
Despite its small size, the graphics card still offers two DisplayPort and two HDMI outputs, supporting up to four external monitors. This makes it a great option for gamers with multiple monitors.
