NZXT Unveils H5 Flow Starfield Limited Edition Case with Dedicated GPU Fan and Lift 2 Starfield Wired Gaming Mouse
Image: NZXT
NZXT has listed the H5 Flow Starfield and Lift 2 Starfield, a new limited-edition compact mid-tower and wired gaming mouse inspired by Bethesda Game Studios’ latest RPG. They are complemented by the Starfield MXL900, an extra large extended mouse pad.
Pricing:
H5 Flow Starfield features:
  • Pre-installed fan on bottom inside panel is angled to cool GPU
  • Tempered glass front panel and built-in RGB controller
  • Perforated top panel provides optimal ventilation
  • Intuitive cable management system with wide channels, hooks, & straps
  • Tool-less access to front & side panels
  • Front panel supports 2 x 140mm fans or 280mm radiator
  • Top panel supports up to 2 x 120mm fans or 240mm radiator
  • Includes two pre-installed F140 RGB fans & one F120Q fan
Image: NZXT
Lift 2 Starfield features:
  • Lightweight 58 g design enhances maneuverability and control at high speeds, plus minimizes hand fatigue.
  • 8,000 Hz polling rate communicates clicks and movements every 0.125 milliseconds for unrivaled responsiveness.
  • Optical switches enable lightning-fast click response times, consistent precision, and a 100-million click lifetime.
  • 26,000 DPI optical sensor delivers flawless 1:1 tracking performance at any sensitivity and speed.
  • 100% virgin PTFE mouse feet offer ultra-low friction, resulting in silky-smooth gliding and superior movement control.
  • Lightweight, low-drag paracord cable is highly flexible, durable, and tangle resistant—almost like it’s not even there.
  • Symmetrical shape with textured side grips for maximum comfort and secure handling. Best suited for claw and fingertip grip styles.
  • Compatible with NVIDIA Reflex, which measures system latency when paired with NVIDIA G-SYNC displays.
Image: NZXT
Starfield MXL900 features:
  • Stain resistant coating
  • Low-friction surface
  • 900mm x 350mm
Image: NZXT
NZXT on its Lift 2 mice:
NZXT’s Lift 2 mice series redefine precision, boasting an ultra-lightweight form – just 58 grams for the Symm and 61 grams for the Ergo. The impressive 8,000 Hz polling rate captures clicks and movement up to 8x faster than most gaming mice. Optical switches guarantee instantaneous and reliable clicks, while the 26,000 DPI optical sensor ensures impeccable tracking across all speeds and sensitivities.
Discussion (2 replies)
Seems a bit late to the game. Must be counting on whatever future update is coming to Starfield to reinvigorate the consumers.
Niner51
Should have brought a new case along with this theme to get people interested IMO.
