The Cooler Master MK770 just might manage to check almost every box one could be looking at for a mechanical keyboard. It has been designed to be useful for productivity, gaming, and casual use with an emphasis on tactile performance and customization. The Cooler Master MK770 has 98 keys, a rare commodity for gaming keyboards where TKL has dominated in recent times, a noise-absorbing and vibration-reducing gasket structure, RGB, Kailh Box V2 Switches, and is compatible with Windows, Mac, iOS, and Android. Connectivity options include USB Type-C, Bluetooth 5.1, or 2.4 GHz. It is available in Macaron or Space Gray color schemes.
MK770 Feature Highlights (per Press Release):
- Built for Endurance with Unmatched Durability and Tactile Control
- Hot-Swappable Switches
- Smooth Typing with KailhBox V2 Switches and Gasket Structure
- Radiant RGB Backlighting with Noise-Absorbing Design
- Next-Level Stabilizers and Seamless Connectivity
- Wide Compatibility (Windows, Mac, iOS, Android)
- Available in Various Striking Colorful Design Options
Specifications (per product page):
Product NumberMacaron: MK-770-MCKR1/W1/M1-**, Space Gray: MK-770-GKKR1/W1/M1-** |
Keyboard Switch Type: Kailh Box V2 Switch |
Keyboard Keycaps: PBT Double-shot Keycap (US/TC), ABS Paint & Laser-engraved Keycap (Other layout) |
LayoutANSI: 98Key layout, ISO: 99Key layout |
Keyboard Material: ABS |
Keyboard Color: Macaron, Space Gray |
Keyboard LED Color: RGB, 16.7 million colors |
Keyboard Polling Rate: 1000Hz (Wired/2.4GHz Mode), 125Hz (Bluetooth Mode) |
Keyboard Response Time: 1ms |
Keyboard On-board Memory: 128 KB |
Keyboard On-the-fly System: Yes |
Keyboard Multimedia KeyThrough Function Key (FN) |
Connectivity: Wired, 2.4 GHz, Bluetooth 5.1 |
Charging: Support Wired charging |
Battery: 4000mah |
Compatible OS: Windows 8+, Mac OS X 10.10+, Android, iOS |
Software Support: MasterPlus+ Support |
Keyboard Connector Cable: USB Type-C (Keyboard Side), USB 2.0 Type A (Computer Side) |
Keyboard Cable: 1.8m, USB Type-C Detachable & Coiled Braided |
Keyboard Dimensions: (L x W x H)Standard: 380.89 x 140.42 x 38.74mm, Feet Open 1: 380.89 x 140.42 x 42.9mm, Feet Open 2: 380.89 x 140.42 x 45.51mm |
Keyboard Weight:1052g / 2.319 lbs (without cable) |
Product: Keyboard |
Series: MK Series |
Keyboard Type: Mechanical |
