MSI Has Quietly Launched Its Blower-Style GeForce RTX 4070 Ti SUPER AERO on Newegg for $899
Image: MSI
Those looking for a blower-style version of a GeForce RTX 4070 Ti SUPER are in luck as MSI quietly launched its AERO model on Newegg. MSI hasn’t released many consumer graphics cards for its AERO family in North America in recent years. One of the last was in 2020 with its NVIDIA GeForce RTX 3090 AERO, and before that with the RTX 2080 SUPER AERO. MSI has, however, continued to offer various models in Asia and other markets that are geared toward AI, and similar data-focused, applications. Given that Newegg has a bit more access to overseas suppliers it shouldn’t come as a surprise that MSI has quietly launched its latest product there.
As can be seen by the product images the RTX 4070 Ti AERO utilizes a similar design as its AERO predecessors. Occupying only two PCI slots makes it a bit of a rare commodity in the consumer GPU sector especially when taking into consideration that it uses a cutdown AD103 processor, the same found in the RTX 4080 and RTX 4080 SUPER along with similar 16 GB GDDR6X memory. That combined with its blower design which externally vents air from inside the case, presents some interesting possibilities for PC owners be they gamers or those looking to use it for productivity purposes. The card retains the normal 3x DP 1.4a and 1x HDMI 2.1 ports found on other models.
The downside is that MSI has priced it at $100 higher than MSRP at $899 but that is still often far lower than the price of the RTX 4080 SUPER where partner versions can commonly go for up to $1199 or more.
Specifications
  • Model: RTX 4070 Ti SUPER 16G AERO
  • Interface: PCI Express 4.0
  • Boost Clock: 2610 MHz
  • CUDA Cores: 8448 Cores
  • Memory Size: 16GB GDDR6X
  • Memory Interface and Speed: 256-Bit, Effective Memory Clock 21000 MHz (21 Gbps)
  • DirectX: DirectX 12 Ultimate
  • OpenGL: OpenGL 4.6
  • Ports: 1 x HDMI 2.1a, 3 x DisplayPort 1.4a
  • Max Resolution: 7680 x 4320
  • TDP: 285W
  • Recommended PSU Wattage: 700W
  • Power Connector: 1 x 16-Pin
  • Max GPU Length: 263 mm
