The GIGABYTE AORUS FO32U2P Is the World’s First 4K/240 Hz OLED Gaming Monitor Featuring DisplayPort 2.1 UHBR20
Image: GIGABYTE
The GIGABYTE AORUS FO32U2P supports the full 80 Gbps bandwidth available with Displayport 2.1 for its 4K/240 Hz panel. Gaming monitors with DP 2.1 are finally making their way to market but not all support the UHBR20 specification which means they do not support the maximum bandwidth available to the new DisplayPort version. A Samsung QD-OLED panel is used which supports AMD FreeSync Premium Pro to offer a tear-free gaming experience. GIGABYTE has included an array of ports for connecting to either PC or consoles and other devices that span from 1x DP 2.1 UHBR20, mini 1x DP 2.1 UHBR20, 2x HDMI 2.1, and USB Type-C supporting up to 65W power delivery.
The AORUS FO32U2P 10bit panel also supports up to 99% DCI-P3, is factory calibrated, and is VESA DisplayHDR True Black 400 certified. It has a response time of 0.03ms GTG with a contrast ratio of 1,500,000:1. From competitive to casual gaming this 31.5″ display offers a lot of features many gamers could be after. GIGABYTE has not yet announced pricing and availability for the AORUS FO32U2P.
GIGABYTE AORUS FO32U2P Specifications (via product page):
  • Panel Size: (diagonal) 31.5″ OLED
  • Display Viewing Area: (HxV)699.48 x 394.73 mm
  • Panel Backlight/ Type: QD-OLED
  • Display Surface(non-glare/ glare): Anti-Reflection
  • Color Saturation: 99% DCI-P3
  • True Resolution: 3840 x 2160 (UHD)
  • Pixel Pitch: 0.181(H) x 0.181(V) mm
  • Brightness: 250 cd/m2(TYP)
  • Contrast Ratio: 1,500,000:1
  • Viewing Angle: 178°(H)/178°(V)
  • Display Colors: 10bit (1.07B)
  • Response Time: 0.03ms GTG
  • Refresh Rate: 240Hz
  • Clarity to Motion: VESA Certified ClearMR 13000
  • VRR Support: AMD FreeSync Premium Pro
  • HDR: VESA DisplayHDR True Black 400
  • Flicker-free: Yes
  • HBR3: Yes
  • Factory Calibration: Yes
  • Connectivity: 2 x HDMI 2.1, 1 x Displayport 2.1 (UHBR 20), 1 x mini DP 2.1 (UHBR 20), 1 x USB Type-C (Alternate Mode; Upstream port; Power Delivery up to 65W), 2 x USB 3.2 Downstream ports, 1 x USB 3.2 Upstream port, 1 x Earphone Jack, 1 x Microphone Jack
  • Earphone Jack: Yes
  • Microphone Jack: Yes
  • Speaker: 5W x 2
  • Unique Features: Tactical Switch, Daisy Chain, OSD Sidekick *, Black Equalizer 2.0, Dashboard, Crosshair, Timer, Counter, Night Vision, Eagle Eye, PiP/PbP, Auto-Update, KVM, 6-axis Color Control, Apply Picture Mode, HDMI-CEC, RGB Fusion 2.0
  • Power Type: Power Adapter
  • AC Input Max: 78W
  • Power Saving Mode: <0.5W
  • Power Off Mode: <0.3W
  • Voltage: AC 100-240V ~ 50/60Hz
  • Tilt(angle): -5°~+20°
  • Swivel(angle): ±20°
  • Pivot(angle/direction): -0°~+90°
  • Height Adjustment(mm): 130 mm
  • VESA Wall Mounting(mm): 100×100 mm
  • Kensington lock: Yes
  • Phys. Dimension with Stand(WxHxD): 718.3 x 613.6 x 158.6 mm
  • Phys. Dimension w/o stand  (WxHxD): 718.3 x 417.5 x 57.2 mm
  • Box Dimension (WxHxD): 980x580x190 mm
  • Net Weight with stand (Est.): 8.53 kg
  • Net Weight without stand (Est.): 6.2 kg
  • Gross Weight (Est.): 13.2 kg
  • Accessories: Power cable/HDMI 2.1 cable/DP 2.1 cable/USB cable/QSG/Warranty card
