ENERMAX has announced the launch of the ENERPAZO EP237, a new mini-tower PC case that supports ATX motherboards and is said to be ideal for PC DIY newcomers and other entry-level users. One practical feature is its handle pull ring, which users can use to open its magnetic, tempered-glass side panel.
Models/availability:
- Black and white versions now on sale in Japan and Taiwan
- Special White ENERPAZO EP237 edition bundled with 4x ENERMAX SquA RGB PWM fans launching in Europe in March
Features include:
- Compact Chassis Design: The ENERPAZO EP237 is a mini-tower case with dimensions of 410mm(D) x 210mm(W) x 450mm(H)
- Advanced Cooling Support: It supports a 360mm AIO CPU cooler with a 38mm thick radiator and up to eight fans, including one pre-installed ARGB fan for enhanced airflow.
- Superior Expandability: Accommodates ATX motherboards and up to four drive installations, along with seven reusable PCIe slots for extensive customization.
- User-Friendly Features: Features include a handle pull ring on the magnetic transparent tempered glass side panel, ENERMAX cable ties for organized cable management, and dust filters on the top panel for maintenance ease.
- Broad Compatibility: Supports graphics cards up to 365mm in length (without radiator) and CPU air coolers up to 162mm in height, ensuring compatibility with a wide range of components.
ENERMAX on its new case:
This new offering provides efficient cooling support and expandability. It is compatible with an ATX motherboard and allows for the installation of an AIO cooler with a radiator measuring up to 360mm in length and 38mm in thickness. The ENERPAZO EP237 comes equipped with one ARGB fan, seven reusable PCIe slots, and a magnetic transparent full-view tempered glass side panel equipped with a convenient handle pull ring for easy access. These features make the ENERPAZO EP237 an ideal computer case for PC DIY newcomers.
