Cooler Master Announces TD500 MAX PC Case That Comes Pre-installed with 360mm AIO and 850W Gold ATX 3.0 PSU
Image: Cooler Master
PC building is about to get a bit easier as Cooler Master announces its TD500 MAX PC chassis which includes an AIO, PSU, and 2-stage connectors. Cooler Master previously revealed the TD500 MAX back in January but appears to be readying an imminent launch as review embargos have lifted and have begun being posted.
The TD500 MAX has been designed to meet the cooling demands of most high-end components with its 360mm Atmos AIO (we have a review of the MASTERLIQUID version here) featuring a 38mm radiator and 3x Mobius 120P ARGB fans, 1x 120 ARGB fan on the rear, and capable of supporting up to three more fans on the top of the case. Cooler Master also includes a GX II Gold 850W ATX3.0 PSU, plus a 2-stage cable connecting system and storage area for screws.
Official Product Page
Key Features (per original announcement):
  • Advanced Cooling System: Equipped with a 360x38mm Atmos radiator and Mobius 120P ARGB fans for top-tier thermal performance.
  • User-Friendly Building Experience: Pre-installed and pre-routed components for a straightforward assembly.
  • Two-Stage Power Connector: Patent technology for seamless cable management.
  • Exclusive Design and Color Scheme: Unique grey color and custom components for standout aesthetics.
  • High-End Power Supply: GXII 850W ATX3.0 Max version PSU for peak performance and easy installation.
  • Innovative Screw Stock Storage Pad: A simple solution for storing screws during builds and maintenance.
Owners of modern graphics cards, some of which have grown to gigantic proportions, may want to consider the TD500 Max as it is capable of fitting cards up to 380mm in length. The included PSU could be a great pairing for someone with a mid to high-end processor and an NVIDIA GeForce RTX 4080 Super (which we also have a review of here). Pricing and availability have not yet officially been revealed by Cooler Master, yet, but according to one reviewer the TD500 MAX will retail for $399.99. While that potential price may seem high the reviewer noted that if trying to source like-for-like similar parts, it would be just a bit higher.
Specifications:
  • Product Number: TD500V2-MGNN85-SL0 / TD500V2-MGNN85-SL1
  • Exterior Color: Gun metal
  • Materials: Exterior Steel, Plastic, Tempered Glass, Left Side Panel Tempered Glass
  • Dimensions (L x W x H): 499 x 210 x 500mm (incl. Protrusions), 482 x 210 x 477mm (excl. Protrusions)
  • Volume: 48 Liters
  • Motherboard Support: Mini-ITX, Micro-ATX, ATX
  • Expansion Slots: 7
  • Drive Bay: 2x 3.5″ HDD, 3x 2.5″ SSD
  • I/O Panel: 2x USB 3.2 Gen 1 (USB 3.0), 1x USB 3.2 Gen2 x 2 Type C, 1x Audio Combo (Audio In / Out 3.5mm)
  • Included Accessories: ARGB Hub
  • Pre-installed Radiator: ML360 Atmos MAX ver.
  • Pre-installed Power Supply Unit: GX II Gold 850W ATX3.0 MAX ver.
  • Pre-installed Fan(s): Front 3 x 120mm (AIO Mobius120P ARGB fan), Top N/A, Rear 1 x CF120 ARGB fan
  • Fan Support: Front 3 x 120mm / 2 x 140mm, Top 3 x 120mm / 2 x 140mm, Rear 1 x 120mm
  • Radiator Support: Front 360mm / 240mm, Top 360mm / 240mm, Rear 120mm
  • Clearances: CPU Cooler 165m, Power Supply 200mm (Pre-installed PSU Length 160mm), Graphics Card 380mm (with pre-installed AIO on front), Cable Routing – Behind MB Tray 19mm
  • Dust Filters: Top, Bottom
  • Warranty: 2 years (Case), 5 years (Thermal Solution), 5 years (Power Delivery)
  • Form Factor: ATX
