XDefiant, Ubisoft San Francisco’s new free-to-play multiplayer arena shooter, is now available to preload on console and PCs ahead of its release tomorrow on PS5, Xbox Series X|S, and PC via Ubisoft Connect, Ubisoft has announced. The PC specifications for XDefiant, which Ubisoft has also shared, suggest that the game will not be particularly demanding, with players being able to get away with hardware as low as an AMD Ryzen 3 3100 processor and NVIDIA GeForce GTX 1050 Ti graphics card.
PC specifications:
- MINIMUM
- Resolution: 1080p
- CPU: Intel i3-10105F; AMD Ryzen 3 3100
- GPU: Intel ARC A380 (6GB); NVIDIA GTX 1050TI (4GB); AMD RX 5500 XT (4GB)
- RAM: 8 GB Dual Channel
- OS: Windows 10
- Storage: 35 GB
- RECOMMENDED
- Resolution: 1080p
- GPU: Intel ARC A750 (8GB); NVIDIA GTX 1060 (6GB); AMD RX 5500 XT (8GB)
- RAM: 16 GB Dual Channel
- OS: Windows 10
- Storage: 35 GB
- ENTHUSIAST
- Resolution: 1440p
- CPU: Intel i5-10400; AMD Ryzen 5 3600
- GPU: Intel ARC A770 (16GB); NVIDIA RTX 2060 (6GB); AMD RX 5600 XT (6GB)
- OS: Windows 10/Windows 11
- Storage: 35 GB
- ULTRA
- Resolution: 4K
- CPU: Intel i7-9700K; AMD Ryzen 7 3700X
- GPU: NVIDIA RTX 3080 (10GB); AMD RX 6800 XT (16GB)
The specs visualized:
A launch trailer:
Ubisoft on some of the game’s PC features:
…players can begin preloading the game from their console or PC. For those jumping into XDefiant on PC, the game supports DX11 and DX12, uncapped frame rate, widescreen support, and NVIDIA Reflex support for low latency gameplay. To make the most of your specific gaming rig, and to ensure you’re squeezing out every possible frame, check out the full list of recommended PC specifications.
