DeepCool Assassin 4S CPU Cooler Review
Sound Level Testing
100% Fans
DeepCool Assassin 4S max RPM sound testing results
At maximum fan levels, the Assassin 4S was the quietest (44.1 dB(a)), ahead of the CORSAIR A115, and IceSLEET G6 Stealth hit 47.4 dB(A) tying for second place. The Cooler Master MasterAir MA824 barely brought up the rear at 47.8 dB(A). From a subjective perspective, there was not a substantial difference between the coolers.
Note that the max fan speed on the Assassin 4S reached 1850 RPM while the CORSAIR A115 topped out at 1600 RPM, the MasterAir 824 topped out at 1900/1550 RPM and the IceSLEET G6 Stealth topped out at 1450 RPM.
1500 RPM Fans
DeepCool Assassin 4S 1500 RPM sound testing results
Dropping down to 1500 RPM, the Assassin 4S takes the lead at 39.9 dB(A). The CORSAIR A115 lands in second with 45.9 dB(A) of racket and the Master Air MA824 is one decibel louder. The IceSLEET G6 Stealth wins the loudest prize as its single fan is spinning at the same speed as the maximum fan speed test.
1000 RPM Fans
DeepCool Assassin 4S 1000 RPM sound testing results
When we lowered the fans down to 1000 RPM, the Assassin 4S improved its lead with a 37.4 dB(A) result which was slightly quieter than the two double fan entrants (the CORSAIR A115 and MasterAir MA824 Stealth) that produced 38.7 dB(A) of noise. The single fan IceSLEET G6 Stealth sneaks in at 40.9 dB(A). From a subjective perspective, there was no difference in how they sounded at 1000 RPM.
600 RPM Fans
DeepCool Assassin 4S 600 RPM sound testing results
Lowering the fans to 600 RPM brought a three-way tie at 35.8 dB(A) for the Assassin 4S, CORSAIR A115, and MasterAir MA824 Stealth. The IceSLEET G6 Stealth is slightly louder at at 37.4 dB(A). With that said, let’s move on and recap all of this for you today!
Cooling Performance
8.5
Installation Effort
Sound Level
The DeepCool Assassin 4S is a single fan CPU cooler targeted at those looking for good performance while keeping the noise levels down. We tested it on our test bench and found that it was a solid thermal performer while being the quietest of the competition. The Assassin 4S is worth a hard look if you're wanting a very quiet cooler with reasonable thermal performance.
