ASRock Launches AMD Radeon RX 7900 Creator Series Graphics Cards with Blower Fan
Image: ASRock
ASRock has launched the Radeon RX 7900 XTX Creator 24GB and ASRock Radeon RX 7900 XT Creator 20GB, two new Radeon RX 7000 Series graphics cards based on the RDNA 3 architecture that feature a vapor-chamber heatsink, two-slot thickness, and what the company says is an efficient blower fan, swiftly dissipating heat toward the rear of the GPU. The 24GB model boosts up to 2,500 MHz, while the 20GB version boosts up to 2,395 MHz.
Product links:
The 24GB XTX model features:
  • Clock: GPU / Memory
    • Boost Clock: Up to 2395 MHz
    • Game Clock: 2025 MHz
  • Key Specification
    • AMD Radeon RX 7900 XT GPU
    • 20GB GDDR6 on 320-Bit Memory Bus
    • 84 AMD RDNA 3 Compute Units (with RT+AI Accelerators)
    • 80MB AMD Infinity Cache technology
    • 12V-2×6 Power Connector
    • 3 x DisplayPort 2.1, 1 x HDMI 2.1
  • Key Features
    • Multicard For Accelerate Computing
    • Efficiency Blower Fan
    • VAPOR-CHAMBER Heatsink
    • Stylish Metal Backplate
A closer look at their vapor chamber design:
Image: ASRock
ASRock on its latest GPUs:
ASRock Radeon RX 7900 Creator series graphics cards are powered by the AMD Radeon RX 7900 XTX and Radeon RX7900 XT GPUs. Both of these two cards are supporting multi-GPU collaborative computing, and designed for multi-card parallel computing for better performance. Radeon RX 7900 Creator series graphics cards are featuring a VAPOR-CHAMBER heatsink, efficiency blower fan and 2-slot thickness. Furthermore, thanks to the single horizontal 12V-2×6 power connector, to install couple of ASRock Radeon RX 7900 Creator series graphics cards become much easily due to less power cords.
In additional, the blower fan of ASRock Radeon RX 7900 Creator series graphics cards support 0dB Silent Cooling for great cooling efficiency, and a metal frame provides solid construction. Undoubtedly, ASRock Radeon RX 7900 Creator Series graphics cards are outstanding choices for gamers and creators.
