ASUS Unveils Nine AMD X870/X870E AM5 Motherboards for Ryzen 9000 Series “Zen 5” Processors, including NitroPath DRAM Technology for Faster Memory Speeds and Enhanced Slot Retention
Image: ASUS
ASUS has introduced its first X870E/X870 AM5 motherboards for AMD Ryzen 9000 Series processors, and with it comes the specifications for at least nine models that will be available under the company’s ROG, TUF Gaming, Prime, and/or ProArt brands, including the ROG CROSSHAIR X870E HERO, a flagship, AI PC-ready motherboard that is said to be unrivaled for gaming immersion, featuring a robust power solution with 18+2+2 power stages, massive heatsinks integrated with the I/O cover, and other premium features for pushing the limits of Zen 4 and Zen 5 CPUs. NitroPath, a new DRAM technology, was also announced by ASUS today, advertised to increase DRAM overclocking performance on X870E motherboards by up to 400 MT/s.
Product links:
Specs for the flagship ROG CROSSHAIR X870E HERO include:
SizeATX
Memory4 x DIMM, Max. 192GB, DDR5
PCIe2 x PCIe 5.0 x16 (@x16 or @x8/x8 or x8/x4/x4)
Storage3 x M.2 2280 (PCIe 5.0 x4)
2 x M.2 2280 (PCIe 4.0 x4)
SlimSAS connector (PCIe 4.0 x4)
NetworkingWi-Fi 7
1 x Intel 2.5Gb Ethernet
1 x Realtek 5Gb Ethernet
AudioROG SupremeFX 7.1 Surround Sound High Definition Audio CODEC ALC4082
ESS ES9219 Quad DAC
Rear I/O2 x USB4 40Gbps ports (2 x USB Type-C)
8 x USB 10Gbps ports (6 x Type-A + 2 x USB Type-C)
Front I/O1 x USB 20Gbps connector (supports USB Type-C) with QC 4+ up to 60W
2 x USB 5Gbps headers (support 4 USB 5Gbps ports)
2 x USB 2.0 headers (support 4 USB 2.0 ports)
Aura3 x Addressable Gen 2 headers
Cooling1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
4 x 4-pin Chassis Fan headers
1 x W_PUMP+ header
NitroPath DRAM technology is debuting on:
  • ROG Crosshair X870E Hero
  • ROG Strix X870E-E Gaming WiFi
ASUS on NitroPath:
  • “NitroPath DRAM Technology boosts memory speeds through our exclusive layout routing.”
  • “This cutting-edge design reduces noise interference via shorter gold finger pins and optimized signal pathways within the motherboard, increasing DRAM overclocking performance by up to 400MT/s.”
  • “NitroPath DRAM Technology offers enhanced slot retention force, too.”
Those improvements include:
DDR5 DRAM Latch Lateral Force (Latching)
Traditional SlotNitroPath DRAM SlotImprovement
6.23 kgf7.46kgf20%
DDR5 DRAM Latch Lateral Force (Release)
3.88 kgf4.84 kgf25%
DDR5 DRAM Slot Retention Force
4.72 kgf7.42 kgf57%
Highlights from today’s press event:
ASUS on the difference between X870E and X870:
Your most feature-rich, high-end options for your AMD Ryzen 9000 Series CPU use the X870E chipset. Armed with DDR5 support, PCIe 5.0 connectivity for graphics and SSDs, two onboard USB4 ports, and support for the latest CPU and memory overclocking refinements, these motherboards are ready to push your new CPU to its limits. Since X870E motherboards have two chipsets, they have more PCIe lanes to play with. On the ProArt X870E-Creator WiFi, for example, we put them to work with a Marvell 10Gb Ethernet port.
Source (1, 2)
