24.06-10.00.00, a new system software update that delivers several new features for PS5 consoles, including Welcome hub, Party Share, personalized 3D audio profiles, and adaptive controller charging, is now available for download, Sony Interactive Entertainment has announced. Adaptive controller charging, a feature that Sony says helps save power by adjusting the length of time that power is supplied to PlayStation controllers based on their battery level, is available for the slimmer PS5 model now, and the PS5 Pro when it releases on November 7 for $699.99.
Key features of the update, per Sony executive Hiromi Wakai:
- “Welcome hub: a new personalized space with customizable widgets and backgrounds in your PS5 home screen.”
- “Party share: the ability to share party voice chat links on messaging and social media apps will roll out globally in the coming weeks.”
- “Personalized 3D audio profiles for headphones and earbuds.”
- “Adjust Remote Play settings per user and choose who is allowed to connect to your PS5 console using Remote Play.”
- “Adaptive charging for your controllers (available for the slimmer PS5 model and PS5 Pro when it’s available)”
A look at the new Welcome hub, including how to set up a personalized 3D audio profile:
The full patch notes:
- The Welcome hub is now available in the home screen. For users in North America, this enhancement replaces the Explore hub.
- You can customize the Welcome hub with widgets and backgrounds.
- Widgets display information like storage, battery levels, online friends, and more.
- Widgets can be added, removed, resized, and moved one by one. You can also choose from preset widget layouts based on your preferences.
- A limited number of users will receive the Welcome hub in this update. All users worldwide will receive this enhancement within 1-2 months.
- You can now create a personalized 3D audio profile for your headphones that’s optimized to each user’s ears. This allows for a more immersive 3D audio experience than ever before.
- Each 3D audio profile is uniquely optimized for each user, created by taking detailed measurements of how you hear 3D audio through headphones.
- To create a personalized 3D audio for your headphones, go to Settings > Sound > 3D Audio (Headphones).
- You can still select from 3D audio presets like before.
- Adaptive charging for your controller is now available for when your PS5 (CFI-2000 model group)is in rest mode.
- Adaptive charging allows the duration of power supply during rest mode to adjust depending on how much battery your controller has left, helping save power.
- To use adaptive charging, go to Settings > System > Power Saving > Features Available in Rest Mode, and then select Supply Power to USB Ports > Adaptive.
- Adaptive charging is supported on the PS5 CFI-2000 model group, using the USB Type-C port. Adaptive charging works with the DualSense wireless controller, DualSense Edge wireless controller, PS VR2 Sense controllers, and Access controller.
- After your PS5 enters rest mode, if a controller isn’t connected, the power supply to the USB port will stop after a certain period of time.
- When you’re in a party, you can now share a link to that party. Share the link with players using other services to invite them to that party.
- This feature will be gradually rolled out after this system software update is released.
- You can now set which users can connect to the PS5 using Remote Play.
- Go to Settings > System > Remote Play > Enable Remote Play, and select the users who can access your console through Remote Play.
- The restore licenses feature has been improved, and you can now restore one license at a time.
- Go to Settings > Users and Accounts > Other > Restore Licenses to select the license that you want to restore.
- To restore a license from the home screen or Game Library, go to the game, press the options button, and then select Restore License from the menu.
- We’ve added a friendly recommendation about your storage space that you’ll sometimes see in Settings > Storage.
- We’ve made it simpler to access the most popular activities from game hubs.
- Game hubs now only display activities that are currently in progress.
- To play a specific activity, start the game first and find it using in-game menus.
- The Invite to New Game option, which is available from multiple locations, is no longer available when sending game invites.
- To invite friends to a game session, start the game first, then send the invitation to the session.
- We’ve updated the device software of the DualSense and DualSense Edge wireless controllers, PlayStation VR2 Sense controllers, and Access controller to improve stability.
- We’ve improved system software performance and stability.
- We’ve improved the messages and usability on some screens.
Wakai on adaptive charging and the controllers that are supported:
Adaptive charging for the DualSense wireless controller, DualSense Edge wireless controller, PlayStation VR2 Sense controllers, and Access controller is now available for the slimmer PS5 model, when the console is in rest mode (and will also be available for PS5 Pro when it launches). Adaptive charging helps save power by adjusting the length of time that power is supplied to your controller based on its battery level.
To use adaptive charging, go to [Settings] [System] [Power Saving] [Features Available in Rest Mode], and then select [Supply Power to USB Ports] [Adaptive]. After your PS5 enters rest mode, if a controller isn’t connected, the power supply to the USB port will stop after a certain period of time.
