The XG-C100C V3, a new 10GBASE-T PCIe network adapter that is said to deliver astounding data-transfer speeds, featuring support for 10 Gbps networking and universal compatibility with current networking standards (i.e., 10/5/2.5/1 Gbps to 100 Mbps), is coming to retail, ASUS has announced. Users will find a single RJ45 port, which supports standard copper network cables for what ASUS has described as being easy migration.
Key features include:
- “Hyper-fast 10Gbps Networking – Achieve astounding data-transfer speeds, 10 times faster, ideal for bandwidth-intensive tasks.”
- “Universal Compatibility – XG-C100C supports current network standards, from 10/5/2.5/1Gbps to 100Mbps, ensuring smooth backward compatibility.”
- “Windows and Linux Support – Flexible OS integration with Windows 11/10 and Linux Kernel.”
- “RJ45 Port for Easy Migration – Effortlessly transition to 10Gbps networking using standard copper network cables through the convenient RJ45 port.”
- “Prioritize Your Games – Built-in Quality-of-Service (QoS) technology allows you to prioritize bandwidth and gaming packets, delivering a lag-free gaming experience.”
A look at its cable compatibility:
ASUS on some of the network adapter’s key features:
XG-C100C uses next-generation 10GBase-T (10G) networking technology to deliver speeds of up to 10Gbps –10X faster than standard gigabit Ethernet. It enables ultra-fast 10Gbps network access for desktop PCs, so you can easily handle the most data-intensive tasks in your office or at home.
XG-C100C supports 10/5/2.5/1Gbps and 100Mbps networking standards. It’s designed to provide you with the latest technology, while ensuring full backward compatibility with your existing network infrastructure. Full compatibility with Windows 10 and Linux Kernel allows flexible OS integration.
