Lian Li Launches the DK-07 PC Desk That’s Also A Two System Case
Lian Li announced the DK-07 Dual PC Motorized desk as the successor to its DK-04/05 PC desk. The DK-07 can be configured to house either a single or two E-ATX systems, has a pair of drawers, wireless charging, USB Type-C and Type-A charging ports and can motor up and down between a sitting and standing mode. The $1399.99 MSRP is $100 less than the DK-04 was priced at and significantly lower than the $2k that we paid for our dual system DK-05F.
Available on NewEgg starting today for $1399.99
DK-07 Prototype
At Computex 2023, we took a look at the prototype of the DK-07. At the time, it was planned to only be a single rig case, have an integrated drink chiller and instead of drawers, a hinged door to access the storage compartment. The version launching today seems to be improved across the board and at a surprisingly lower price than expected.
Press Release
November 7th, 2024, Taipei, Taiwan – LIAN LI Industrial Co. Ltd., a leading manufacturer of chassis and PC accessories, launches the latest edition of its motorized desk series with the DK07. The LIAN LI DK07 motorized standing desk is designed with adaptability and performance in mind, seamlessly integrating a single powerful system or dual E-ATX setups. It offers ample space and efficient cable management, featuring built-in cable clips, a large underbelly cable tray, and 2 organizer drawers for a clutter-free workspace. It also includes convenient features like a wireless charging pad with built-in USB ports, ensuring your devices stay powered and your workspace remains organized. The DK07 is available in black at an MSRP of $1,399.99.
Customizable Cooling and PerformanceBuilt for power users, the desk seamlessly supports both single and dual-system configurations, with a modular bracket design at the rear that enhances compatibility and simplifies the installation process when switching between systems. Each system tray accommodates E-ATX motherboards, CPU coolers up to 180mm, and GPUs up to 383mm, vertically or horizontally mounted (for vertical installation, a riser cable sold separately is required). The desk supports various radiator sizes up to 360mm, with multiple fan configurations for optimized cooling, including mounting locations for up to 12 x 120mm fans or 6 x 120mm 4 x 140mm fans, and space for up to 6 x 3.5” HDDs in the front. The modular design allows even more flexibility, with the front radiator brackets supporting 480mm or 420mm + 240mm radiators for enhanced cooling solutions.
Convenience and Connectivity
On the top right corner of the desk, an independently powered wireless charging pad is integrated into the design, with a clever pop-up mechanism revealing hidden Type-C and Type-A ports for power delivery. These features ensure your devices stay charged and your essential connections remain accessible. The DK07 ensures superior cable management with built-in cable clips located at the rear of the desk to route your monitor and peripherals cable cleanly, a large cable tray at the bottom, and two spacious drawers at the front to maintain a clean, clutter-free workspace. Each system includes front I/O panels that feature 2 x USB Type-A and 2 x USB Type-C (USB Gen2x2 with up to 20Gbps transfer speeds) ports, alongside audio/mic jacks—ensuring that all devices remain easily connected.
Elegance Meets FunctionalityThe DK07 redefines the workspace experience with its motorized height adjustment system, offering a smooth transition from sitting to standing with a range between 676mm to 1162mm. The control system, conveniently placed on the top left of the desk, features manual controls and three customizable presets for quick adjustments. Designed with aesthetics and durability in mind, the DK07 boasts a 2mm thick brushed aluminum exterior with 6mm tinted tempered glass on the top, offering a sleek, modern view of your system.
Availability​ The DK07 is available on November 7th, 2024, at an MSRP of $1,399.99.
Specifications
ModelDK07
Case TypeMotorized Desk
Dimensions1480 x 805 x 676-1162mm
ColorBlack / White
MaterialSteel
Tempered glass
Aluminum
Motherboard Support2 x E-ATX / ATX / MICRO-ATX/ MINI-ITX
Expansion Slot7
StorageDual System:
3.5” HDD x 10 + 2.5” SSD x 4
Single System:
3.5” HDD x 10 + 2.5” SSD x 6
GPU Length Clearance383mm(Max)
CPU Cooler Height Clearance180mm (Max.)
PSUATX (Under 220mm)
Fan SupportDual System:
Back: 2 x 120Right Side: 2 x 120Front: 6 x 120 or 4 x 140Left Side: 2 x 120
Single System:
Back: 1 x 120Right Side: 2 x 120Middle Right: 3 x 120Front: 6 x 120 or 4 x 140Left Side: 2 x 120Middle Left: 3 x 120
Radiator SupportDual System:
Front: 2 x 360 / 2 x 280 / 360 / 280 / 240 / 140 / 120mm radiator
Single System:
Middle Right: 360 / 240 / 120 mm radiatorFront: 2 x 360 / 2 x 280 / 360 / 280 / 240 /140 / 120mm radiatorMiddle Left: 360 / 240 / 120 mm radiator
I/O PORTSSystem 1: Power + Reset + USB 3.1 Type C x 2 + USB 3.0 Type A x 2 + Mic/Audio x 1
System 2: Power + Reset + USB 3.1 Type C x 2 + USB 3.0 Type A x 2 + Mic/Audio x 1
Dust FiltersDual System:
Front x 2 / Right Side x 1 / Left Side x 1
Single System:
Front x 2 / Right Side x 1 / Left Side x 1 / Middle x 2
