(PR) Antec Inc., a global leader in high-performance computer components and accessories, is proud to announce the launch of the Antec CX600M Trio Mid-Tower Gaming Case. This latest addition to Antec’s chassis lineup combines compact design with cutting-edge modern style, delivering a jaw dropping microATX case that’s perfect for modern, high-performance PCs.
Triple Transparent View
Display your build through the top, front and side with seamless tempered glass panels. The well-crafted CX600M Trio ARGB provides you with the ultimate unobstructed view.
Dual Chamber
Dual chamber design ensures independent cooling for CPU/GPU on the left and PSU / Drives on the right.
Vertical Cooling with massive air intake
A large amount of air is taken in through the bottom and side, facilitating heat dissipation and protect hardware from overheating. The 1.5 mm fine mesh on the right side prevents dust entry.
Pre-installed 3 x 120 mm ARGB/PWM Fans.
Use the major case fan to daisy-chain the other two fans for ARGB sync and create your personal style.
Support for Dual Radiators
Supports the simultaneous installation of a 360 mm radiator on the bottom and a 240 mm radiator on the side.
MSRP
The stunning CX600M Trio is aggressively priced at only €109 / £89.99 street price, allowing you to spend more of your budget on other components. Price without compromise!
Availability
The black model of the Antec CX600M Trio will be arriving into stock with resellers in the next 1-2 weeks. The white model will be arriving a little later with an expected arrival date of January.
