SilverStone Unveils First Micro-ATX Workstation Chassis with Support for Rear-Connector Motherboards
Image: SilverStone
(PR) SilverStone Technology, a trusted name in innovative PC hardware, is thrilled to unveil its latest addition to the acclaimed SETA series – the SETA H2M, a Micro-ATX mid-tower chassis that redefines compact power, premium cooling, and versatility for gamers and creators alike.
With a focus on both compactness and exceptional cooling potential, the SETA H2M is purpose-built to meet the demands of today’s high-performance components. Engineered from high-grade steel, this chassis delivers a robust structure while maximizing compatibility with Micro-ATX systems. It is crafted with a perforated front mesh panel to ensure efficient airflow, backed by two pre-installed 160mm intake fans and a rear 120mm exhaust fan for a seamless, front-to-back airflow design.
To meet evolving cooling needs, the SETA H2M supports up to nine fan mounts when using 120mm fans across the chassis, ideal for achieving positive air pressure and balanced intake/exhaust. For liquid cooling, it provides flexibility with space for a 360mm radiator at the front and a 280mm radiator at the top, allowing users to confidently run the latest CPUs and GPUs with optimal temperature management.
Inside, the SETA H2M offers native support for Micro-ATX motherboards, including rear-connector layouts. Integrated cable pass-throughs and grommets simplify cable management, enhancing ease of use without compromising the strength of its all-steel frame.
Designed with generous storage options, the SETA H2M accommodates up to eight 2.5″ SSDs, catering to storage-heavy setups often required in gaming rigs or compact workstations. It also includes five PCI slots and has a 350mm clearance for modern graphics cards, allowing support for many triple-fan GPUs.
